Notching crossmember to clear header? CRX
Sorry to post this in here, but I figured I would get a better response than in the CRX forum. Move if necessary.
It's a 90 CRX Si with a D16, stock mounts.
With the crossmember bolts loosened about 1/4" the crossmember clears the header. With the bolts torqued, the crossmember barely touches the header. Not enough room to get a piece of paper between, but not close enough to leave a mark on the header.
Would notching the crossmember about 1/4" where needed be acceptable? 1/2" if needed?
I'd rather notch it. Have a welder so adding some reinforcement to its not a problem if that would be needed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina »</TD></TR><TR><TD CLASS="quote">I'd rather notch it. Have a welder so adding some reinforcement to its not a problem if that would be needed.</TD></TR></TABLE>
you answered your own question
just do it!
just do it!
i have done that quite some times
