gas lens setup?
Old Jan 4, 2008 | 08:58 PM
dbiker207's Avatar
Default gas lens setup?
i have a thermal arc arcmaster 185 and i want to upgrade to a gas lens. i cant find any info on what i need to buy or what size my torch is. could someone list all the parts i need to use a gas lens. i think i need a gas lens collet body, a gas lens and an alumina cup for a gas lens.
Old Jan 5, 2008 | 07:01 AM
robbbby's Avatar
Default Re: gas lens setup? (dbiker207)
you have a number 17 torch.
go into any local welding supple store and tell them you want a gas lens for a no.17
you will need a gas lens with is the actual collet body, you can reuse your normal collets and you need new cups and you will also need a little adapter fitting, i can't for the life of me remember what it is called but it is that little white ring that sits at the base of the torch, you will need one for a gas lens and it pretty much stacks on top of your existing one.
Old Jan 5, 2008 | 08:48 AM
dfoxengr's Avatar
Default Re: gas lens setup? (robbbby)
buy off ebay its cheaper.
Old Jan 5, 2008 | 09:34 AM
robbbby's Avatar
Default Re: gas lens setup? (dfoxengr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">buy off ebay its cheaper.</TD></TR></TABLE>
even after shipping? seems like a hassle for something so small
i bought my 1/16 and 3/32 lenses from a welding supply store in michigan for like 8 or 9 dollars each, cups are like a buck or two each.
i bought the smaller diameter gas lens though so maybe that is pricey.
Old Jan 5, 2008 | 01:27 PM
G2turbo_terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by robbbby &raquo;</TD></TR><TR><TD CLASS="quote"> you will also need a little adapter fitting, i can't for the life of me remember what it is called but it is that little white ring that sits at the base of the torch</TD></TR></TABLE>
Insulator
I wait and buy a lot of stuff online VS the local welding store, I'm paying about half what this stuff would go for at the welding store. If it a part here and there, I buy local.
mrlegoman
Welding / Fabrication
Feb 16, 2007 02:35 PM
*Boostwerks*
13
Dec 19, 2005 02:01 PM
whole9
13
Mar 28, 2005 03:36 AM
Engloid
Dec 6, 2004 09:05 PM
