alright guys need some enlightenment about nitrous and my engine
ok so im thinking about nitrous v.s. turbo first and i want to do nitrous cause few people in my area us it. however i dont know what delivery system would be best for my engine. i also dont know what size shot would be good or if i need to get a tune with it to keep it safe. i have a 00 si which has the b16a2 so any info you guys can give me such as links or just stuff you know that would be amazing. i appreciate any help you guys can give!
So your motor is comepletely stock right.Well a safe kit is always a wet system either by nos or nx.plus a tune on the dyno will give you the most power and the safest way to tune your motor with it.For a stock block im guessing 50 shot but your tuner will probably tell you whats the safest route to go.
hey thanks man. anyone know a good site to do some good research on?? because i wanna know to what my tuner is talking about to make sure they dont screw me over on prices and ****. they arent always the most honest at the place around where i live
he better know it, he use to work for nitrous express...lol. But yeah Jeromie aka FMUNK, would be able to answer all the N20 (not NOS) questions.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT’S ME DAVID »</TD></TR><TR><TD CLASS="quote">So your motor is comepletely stock right.Well a safe kit is always a wet system either by nos or nx.plus a tune on the dyno will give you the most power and the safest way to tune your motor with it.For a stock block im guessing 50 shot but your tuner will probably tell you whats the safest route to go.</TD></TR></TABLE>
you can sqeeze 100 shot in a b16 with a good tune check this thread out https://honda-tech.com/zerothread?id=2119397
I would use a dry kit. Jet it small and work up from there. On a stock set up and with "a not so trust worthy tuner" I wouldnt trust nothing but a dry shot. Its simply, easy to use, and doesnt need to be tuned. Set the bottle psi at around 900psi and spray the **** out of it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecallmotor »</TD></TR><TR><TD CLASS="quote">I would use a dry kit. Jet it small and work up from there. On a stock set up and with "a not so trust worthy tuner" I wouldnt trust nothing but a dry shot. Its simply, easy to use, and doesnt need to be tuned. Set the bottle psi at around 900psi and spray the **** out of it. </TD></TR></TABLE>
Just curious, but how do you add fuel to that extra nitrous? Or are you only talking about a small shot?
The bottle pressure puts pressure on the fuel regulator and the computer is
in open loop at full throttle, I'm sprayin a 75dry on my type r swap and the
only modifications are that the timing is retarded 2deg and the fuel pressure
is up 10 psi and I've had no problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic Hybrid »</TD></TR><TR><TD CLASS="quote">Hows everyone feelin on a stock internaled b16a with a 50 shot of dry zex?? Any suggestions?</TD></TR></TABLE>
Piece of cake
Piece of cake
i would use a wet kit. 50 should be no prob. i sqeeze 75 (wet) on a stock ls bottom end all day
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simpleteg3 »</TD></TR><TR><TD CLASS="quote">
i would use a wet kit. 50 should be no prob. i sqeeze 75 (wet) on a stock ls bottom end all day</TD></TR></TABLE>
The only reason im sayin dry is cause I bought a dry kit a while back from a friend for real cheap and ive had it sittin around forever. I was thinkin about throwin it in this summer.
Rhythm Racer
12
May 25, 2003 07:23 AM
