Ls/vtec Can i still do it ???
i have a 01 integra and only have 93k on the whole motor . Im thinking to go ls/vtec in a couple of days. Can my motor still handle it ??
It depends on what you are going to do with it. Remember people have done ls vtec's with the b18a1 so the year of the block doesn't have much to do with if it is possible or not. It all depends on what your goals are for it.
i just wanted to have vtec . I dont race my car i just want a little vtec once in awhile when i want to but im not planning to race my car just to go to work and back.
I say don't do it, just because it's not going to last without a build up. With 93,000 on the motor the bearing are probably a little worn adding a vtec head will finish them off a lot quicker.
I have just change the bottom end with ACL bearings . I change the rod bearings and also the main bearings as well.. So my motor should last now thoe right?
would say just go for it, i think it will last and as long as you get the right stuff for it you should be fine, and if you do blow it runn over to the junkyard and pick up another for 50 bucks, or get a new lower mileage engine after yours takes a dump.
To the original poster. Most Honda engines can make 200k miles very easily. If your motor isn't a big time oil burner, i'd say yes, go for it. It all depends on what you want to do. Do YOU, as in YOURSELF, want it? It's as simple as a yes or no answer. If you can't get the parts for a decent price, you'll probably be better off just getting a B16 swap. However, an LS-VTEC motor will be more "torquey" and should outrun the B16 while turning less rpm.
What I would consider if I were you, and it'd be an easier install, and will perform alot better, would be a JRSC. These kits can be found for very good prices. Their condition is something you'll have to worry about for yourself. However, I think a S/C install would be a more cost effective move for you. Then again, if it's VTEC that you want, then that is your choice.
I hope this helps.
I hope this helps.
also i forgot i can use my stock LS ecu or can i use a P28 ecu ?? Do i have to chip it or tune the ecu as well??? well i have both of the ecu right now . what can be my options??
You could chip the ls for vtec or you can just get a stock gsr or b16 depending on what head you are using, i would also sugest chipping any ecu you get, easiest way for hp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sixtodc4 »</TD></TR><TR><TD CLASS="quote">can i also use my stock ls manifold to as well or i have to get a gsr ? </TD></TR></TABLE>
Intake manifold gsr only.
Exhaust manifold, the LS will bolt on, but changes will have to be made where it bolts to the catalytic converter. Good luck!
look for the ls/vtec build thread, its got alot of good information for a RELIABLE ls/vtec. intake manifolds are different. u need a gsr one if u get a gsr head. exhaust is also different but only in length. there's tons of good information out there if u would do alittle reading.
to the one that recommends a s/c kit as a easier option and being cost effective. like most mods u'll need supporting parts to go along with it to make it reliable.
Dude are you crazy? Its a honda motor its probably just got broken in. Also its not like Ls-vtec is pushing the engine you get like 160hp...
EDIT: WHY THE expletive AM I STILL A TRIAL IT HAS BEEN MORE THAN 5 expletiveING DAYS
