d15b vtec originally available in?? Need motor mount help
I have a d15bvtec motor which i replaced the clutch/flywheel in.. had put about 20k miles on it with no problems... somehow the motor mount disappeared.. i bought a replacement stock 89 crx motor mount.. no go.. I would now assume that i used the stock d15bvtec mount, but need to find out what car it came in so I can order the mount
Thanks!!
Thanks!!
you can get the other part of the motor mount that bolts to the engine off any ef or crx and then your new mount will work. im sure the d16z6 has the same mount as a d15b. but i always thought they were different and wouldnt work in a ef.
