help with my motor problem please
Old Jan 4, 2008 | 04:29 PM
projekt-sol's Avatar
Default help with my motor problem please
ok so heres the thing.. last night i took my VC and rockerarm assembly out of my car and replace a valve adjustment screw then today i put it all back together and just finished.. fired up my car for the first time and no leaks. yet the whole car is vibrating like hell.. its idleing at about 1.5 grand.. i rev it up a lil and it sounds like a effin 2stroke dirt bike.. and its running rich with gas coming out the exaust.. i have a faint idea of what the problem is.. im thinking either plugs or plug wires. the motor is a D15b7 help me resolve this please
Old Jan 4, 2008 | 06:08 PM
Default Re: help with my motor problem please (projekt-sol)
bump
Old Jan 4, 2008 | 06:10 PM
Dramier's Avatar
Ummm.....
You did re-time the motor correctly?????? You didn't just pull it off and then stick it back on without making sure all the marks were lined up right?
Old Jan 4, 2008 | 06:17 PM
Default Re: help with my motor problem please (Dramier)
didt think i would need to as i didnt touch the cam or timing belt all i did was unbolt the rockerarm assembly fix it then bolt it back on..
Old Jan 4, 2008 | 07:38 PM
XYRS2LT's Avatar
Sounds to me like the valves are too tight. Recheck your adjustment.
Old Jan 4, 2008 | 07:45 PM
Default Re: help with my motor problem please (XYRS2LT)
intake at 0.07 inch and exust at 0.09 inch right? could it be plugs? i dont know.. this problem has prompted me to go out and buy a CRX with b18c5 in it tho.. relized how much only haveing one car to drive sucks..
Old Jan 4, 2008 | 09:52 PM
bump? i need this fixed and i need a deff. input on this problem.. so far ive heard valves to tight.. but i checked them there all at 0.07 on the intake side with the same amount of drag.. or so i think.. and the exaust side is at 0.09
Old Jan 5, 2008 | 12:05 AM
court's Avatar
25 Year Member
have you completely ruled out the timing theory. (by checking it)
Old Jan 5, 2008 | 10:29 AM
Default Re: help with my motor problem please (court)
ok update its not plugs and wires bought new plugs and wires and stil runs like a dirt bike.. going to go check the timing.. hopefully i didnt bend a valve or something.. im wandering could it be cracked head>
Old Jan 5, 2008 | 11:06 AM
Dramier's Avatar
Check.
Timing.
Do it.
This sounds exactly like you have timing off. Ever heard a domestic V8 with the distributor 180 off? Yeah.
Old Jan 5, 2008 | 12:34 PM
CourtesyBullet's Avatar
You said it's running rich, but is it to the point where it backfires?
Old Jan 5, 2008 | 12:42 PM
random chaos 85's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dramier &raquo;</TD></TR><TR><TD CLASS="quote">Check.
Timing.
Do it.
Old Jan 7, 2008 | 04:24 PM
Default Re: help with my motor problem please (random chaos 85)
checked timing it was dead on. pulled everything back off and put it all on and fired up idled fine and runs great i think it was bc of the rocker arm assembly binding up on the valves.. thanks for all your input
wu tang
Nov 15, 2008 04:02 PM
DesireeEJ6KiD
Oct 29, 2007 06:42 PM
TYPErCRX
Jan 24, 2006 08:42 AM
TYPErCRX
Jan 24, 2006 05:22 AM
