dsm turbo parts???
Old Jan 4, 2008 | 02:46 PM
del_orson's Avatar
Default dsm turbo parts???
I have a obd1 honda and i was wondering which year of dsm injectors i can use to turbo my car. I have a set of 1990's and a set of 1996's to use. I think it is the 96's I need but not sure. Also, can I use the dsm fuel pump. Im only running 6 psi.
Old Jan 4, 2008 | 04:59 PM
Crx Jimmy's Avatar
Default Re: dsm turbo parts??? (del_orson)
for 6psi the stock pump should be fine, you cam use either set of injectors but I beleive they both need a resister box
Old Jan 4, 2008 | 07:50 PM
tegman23's Avatar
you can use either set of injectors and you do need a resister box...i would get a walbro 255 whats $100 a motors alot more
Old Jan 4, 2008 | 10:44 PM
HiProfile's Avatar
Default Re: (tegman23)
I'd use the newer injectors, but just make sure they aren't junk first. Old ones can be clogged, broken, etc. Also the automagic cars use 390cc's, while manuals used 450cc's.
As for the fuel pump, it appears it would do 120-140lph on your car. FYI all non dohc-vtec fuel pumps are 79lph, and dohc-vtec pumps are 139lph. The stock pump 79lph pump can do 200whp, but its not a good idea to go beyond that.
http://www.roadraceengineering...p.htm
Old Jan 5, 2008 | 08:41 AM
del_orson's Avatar
Default Re: (HiProfile)
do i use a honda resistor box?
flood
Dec 30, 2004 05:18 PM
maka
Jun 3, 2004 01:42 PM
yusoslo
Mar 23, 2004 01:54 PM
hondaeg8
Mar 19, 2004 04:56 PM
KevronsEG
Jan 7, 2003 08:01 AM
