red hose too big??
Old Jan 4, 2008 | 01:31 PM
redboy183's Avatar
Default rad hose too big??
ok just swapped my b16a in and i got the b16a3 del sol upper and lower hoses and they fit good everywhere besides the lower hose on the bottom of the radiator. the hose is to wide for the single cam rad and i heard guys use that indian seal stuff which i tried but im still leaking antifreeze drop by drop...anyone have this problem??
Old Jan 4, 2008 | 03:00 PM
welfarepc's Avatar
i think you would be better off stretching a hose over the fitting on the engine that fits the rad snugly.
better than tigtening down a loosy goosy
Old Jan 4, 2008 | 05:11 PM
Crx Jimmy's Avatar
Default Re: (welfarepc)
get a piece of 1" heater hose heat it up and stretch it over the neck then put your larger hose on top and clamp, or get a DA rad
Old Jan 4, 2008 | 07:16 PM
fin781's Avatar
Default Re: (Crx Jimmy)
i dont know if u have already. use a hose clamp from wallmart instead of your oem one. the oem ones dont seal well, ive had that problem before. that and waterweld. hardens in 5 mins no joke. saved my enigne once keep a tube in the car.
Old Jan 4, 2008 | 09:23 PM
redboy183's Avatar
Default Re: (fin781)
thanks for all the advice guys, it def helped
MechEng
Mar 13, 2012 03:17 PM
whiteciv88
Dec 13, 2009 02:43 PM
B16Civic93
Mar 3, 2005 05:15 PM
tthomass
Feb 5, 2005 08:40 PM
GreensleeperB16
Sep 18, 2003 03:55 AM
