LS/VTEC Turbo Build up any suggestions would be good First Turbo build
Hey Guys, just though I would see if i could get some insight into a few thing maybe get a couple of helpful tips on the build here is what i will be using
The BLock
Golden Eagle HD sleeved LS Block (84mm Bore)
Eagle Crank
Eagle H-Beam rods
Mahle 9 to 1 comp pistons
Endyne Block Girdle
Moroso oil pan
The Head
B16 PR3 Head
Port and Polish
3 or 5 angle valve job
Skunk2 Titanium Retainers
Skunk2 Dual Springs
Skunk2 Valves
Cams=?
I will be using a garrett Gt35R turbo(63AR0),Hondata S300, top mount turbo mani, 3 inch turbo back, 255lph walbro,1000cc injectors. I know i left out a few things but the the jist of it any suggestion on parts on things i should get the machine shop to do would be.I am still undecided about the Skunk2 Stage 2 turbo cams i have herad goods thing but not sure if they would work with my setup.
Thanks
The BLock
Eagle Crank
Eagle H-Beam rods
Endyne Block Girdle
Moroso oil pan
The Head
B16 PR3 Head
Port and Polish
Skunk2 Dual Springs
Skunk2 Valves
Cams=?
Thanks
just figured casue i didn't have one laying around i would just go eagle, just hoping to put some good numbers down
many people are making great power on stock cranks.
this was an eagle crank.
i got this from another thread.
https://honda-tech.com/zerothread?id=2183766
well that answers that questions stock is what i am gonna go with now all i need is cams and maybe a few pointers on things to get and things to do when it is getting put together.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thomas@LPS »</TD></TR><TR><TD CLASS="quote">sounds like a good setup! what kinda numbers are you planning on pushing? </TD></TR></TABLE>
use Crower turbo cams.
not GSR, not CTR, just crower, I used all 3 cams including skunk 2 stage 1 cams.
and crower was the best, don't ask me for a dyno plot cause I don't have one.
race results is what I base my decision on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bubblevic »</TD></TR><TR><TD CLASS="quote">i would behappy with 500whp not to sure how much would be possible for lets say a track day?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rudebwoy »</TD></TR><TR><TD CLASS="quote">
if it is in your budget then they are great cams.
i made 520 with a b16 and gsr cams. it can be done.
using maz v1 cams now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tunedbycft »</TD></TR><TR><TD CLASS="quote">Go with the STOCK crank & get a set of Skunk2 Stage 3 Tuner cams!
Fernando @ CFT</TD></TR></TABLE>
why Tuner3's over Tuner2's?
this guy that works on some of my buddys car says that the driveability for a daily would be terrible just wanna make sure i don't leave something out?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">many people are making great power on stock cranks.
https://honda-tech.com/zerothread?id=2183766</TD></TR></TABLE>
im sry but thats not a vaild response to if anyone has questions about using an eagle crank. its about as useless as when people say use CP pistons over xxxx brand. theres a shitload of pics that have broken CP's, but CP has since resolved the issue and blah blah blah. most companies resolve issues. why wouldnt eagle ?
and to the OP im not knocking the stock crank cause straight from the factory its forged and very robust.
Wow you and me building the same thing, I had alot of the same questions, glad to see some the answers.
I have b18a block
pr3 head
going skunk2 tuner2 cams, and head internals
havent decided on pistons but 9:1 for sure
in a 91 civic hatch
I have b18a block
pr3 head
in a 91 civic hatch
My one suggestion/criticism of the build is this: Did you look around and investigate your options for the turbo before deciding on the GT35r?? I'm not saying its a bad turbo; just that there are other options out there that you may want to consider before going forward. The Borg Warner S366 would be a good one to research in a little more depth....
