NEED HELP on LS swaps EXHAUST SYSTEM in 94 civic!!
Need help guys. My swap came out great with everyones help on Honda-tech. Right where the header and the cat. converter (STOCK 94 CIVIC ) meets, the header from the LS (2000) motor stick out striaght not in the middle but over to the driver side. Its also short about 3-4 inches away from the cat.
Any ideas that can help me out here, or should I have to take it into a exhaust shop? Thanks for helping out..
I have a LS in my 92 hatch... also came along with the same problem.
I found 2 solutions...
Use stock integra piping.
Or the method i used.... got a Omni Power test pipe. it closed the 3-4" gap. and my exhaust is custom from cat back so it barely even looks like its on a slight angle
Which shop did you go through to get the Omni Test pipe? By chance do you know the lenght of the test pipe is? Can I use my stock civic catback exhaust with the test pipe? Thanks.
I got the test pipe from OptionJDM up here in Toronto
http://www.optionjdm.com
But many other places offer them.
Off the top of my head, i dont know the exact length of it tho.
And yes it can bolt right up to your civic catback
Lee_eg6si
Jan 4, 2008 01:52 PM
Lee_eg6si
Jan 4, 2008 01:19 PM
japan4racing
May 22, 2005 09:03 AM
