liberty gear cuff install
Old Jan 4, 2008 | 11:28 AM
SPOOLINmatt's Avatar
Default liberty gear cuff install
Im not a master at honda transmissions but i have replaced synchros and taken my stacks apart to do so and all of that. I got my gear cuff and it has 2 shims. Where do they go? Also, the big bearing that goes on the countershaft side doesnt seem to be pressed in all the way, a good 1/4 inch of it is sticking out and its not seated against the cuff in the bottom side of it. I have searched and there isn't any info on this.
Old Jan 4, 2008 | 12:09 PM
DaveF's Avatar
Default Re: liberty gear cuff install (SPOOLINmatt)
the bearing should move in and out of the cuff pretty "freely" no ?? i belive the shims are for under the bearing on the countershaft.
Old Jan 4, 2008 | 12:19 PM
Default Re: liberty gear cuff install (DaveF)
yeah the shims go under the countershaft bearing i figured that part out, and yes the counter shaft bearing does slide freely, but the mainshaft bearing looks like its half way pressed.
Old Jan 4, 2008 | 12:22 PM
pic
Old Jan 4, 2008 | 12:29 PM
PHDZINE's Avatar
The main shaft bearing is fairly loose. If you put enough pressure on it, it will go down. When I got mine, I was able to move that bearing up and down with my fingers with little effort....you shouldn't need a press.
Old Jan 4, 2008 | 12:40 PM
Default Re: liberty gear cuff install (PHDZINE)
mine wont move, i guess its jammed, it looks a little crooked.
edit: i got it unjammed. I think all is well now.
shims go under the countershaft bearing, pretty much as they came packaged.
Old Jan 4, 2008 | 12:46 PM
redboost10's Avatar
when i ordered mine i asked the same question. it took a while to get a hold of them but they told me to install it just how you recieved it with a shim on each side, just like it was ziptied...
Old Jan 4, 2008 | 12:52 PM
Default Re: liberty gear cuff install (redboost10)
yeah but the shims are not one on each side, they are both on the "bottom" side of the cuff bearing...others have told me to put both bearings on the bottom.
Old Jan 4, 2008 | 01:01 PM
redboost10's Avatar
hmm, sorry, i misunderstood. ive had mine for about a year and a half, when i got mine, there was one shim on each side. weird...
Old Jan 4, 2008 | 01:03 PM
well ****, someone that has done it lately, can you shed light? shim on bottom, one on each side, or what?
Old Jan 4, 2008 | 01:05 PM
boostedcivicsir's Avatar
Mr. Badwrench
if you call liberty and ask for the honda guy, forgot his name, jeromie told me to call him he walked me through the install.
Old Jan 4, 2008 | 01:15 PM
DaveF's Avatar
Default Re: liberty gear cuff install (boostedcivicsir)
both on the bottom.
i belive the guy at liberty you want to talk to name is Paul
Old Jan 4, 2008 | 01:24 PM
AllMoToRB18c's Avatar
does Liberty have a website and do they offer anything for Kseries?
Old Jan 4, 2008 | 02:03 PM
Default Re: liberty gear cuff install (rota92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">It's libertysgears.com I think, give them a call about their K stuff though.
All of their trannies are SICK.</TD></TR></TABLE>thanks man...its something that ive been trying to look into but not sure if i want to spend the money.I heard Magnus Motorsports makes a good tranny too
Old Jan 4, 2008 | 02:48 PM
PHDZINE's Avatar
Both shims go on the bottom of the countershaft bearing. With both shims on the bottom, it places that bearing .050-.060" higher than the cuff...so when you put the tranny cover on and flip the tranny over for the C-clip to catch the countershaft bearing, the cuff will sit center of the cuff bearing.
If that made any sense?
Old Jan 4, 2008 | 08:07 PM
yeah it makes enough sense lol. ive never flipped the tranny to make the c clip latch on to the counter shaft bearing, i guess that might make it a little easier? I always hate releasing the countershaft from the c clip, THAT **** IS A PAIN SOMETIMES.
Old Jan 7, 2008 | 05:32 AM
bruised eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt &raquo;</TD></TR><TR><TD CLASS="quote">yeah it makes enough sense lol. ive never flipped the tranny to make the c clip latch on to the counter shaft bearing, i guess that might make it a little easier? I always hate releasing the countershaft from the c clip, THAT **** IS A PAIN SOMETIMES. </TD></TR></TABLE>
I've always just made sure the input shaft if off the table and the countershaft just drops right out, (I use big snap ring pliers)
princetom
Mar 24, 2015 07:16 AM
ekhaze
Transmission & Drivetrain
Mar 25, 2011 01:57 PM
95_Civic_4dr
Jan 25, 2011 10:26 PM
Wes V
22
Oct 25, 2003 12:51 PM
