cracking the solenoid?
Old Jan 4, 2008 | 10:48 AM
em1_fox's Avatar
Default cracking the solenoid?
i know dat if u crack the solenoid it will hit hard and make vtec louder..my question is this..how would i crak the solenoid..wut would i need to do to make it hit hard and make it louder..any advice..
thank you..
Old Jan 4, 2008 | 10:51 AM
OMGWTFBBQ!'s Avatar
This has to be a joke.
Old Jan 4, 2008 | 10:53 AM
kaiba's Avatar
Default Re: cracking the solenoid? (em1_fox)
You'll need a JDM hammer to crack it.
Old Jan 4, 2008 | 10:54 AM
em1_fox's Avatar
Default Re: (OMGWTFBBQ!)
no its not a joke man..im seriouse..can u tell me how to do it..
Old Jan 4, 2008 | 10:56 AM
ukdmegg5's Avatar
Default Re: cracking the solenoid? (kaiba)
Get your flame suit on
Old Jan 4, 2008 | 10:58 AM
Cln94EG1's Avatar
You Stand in a bucket of water and grab a wrench and touch the + and - Terminals on your battery and have your buddy in the car rev up passed 5k so u can hear it and feel how strong it is now if u happen to get a shock I'm not responsible for that lol
Old Jan 4, 2008 | 10:59 AM
OMGWTFBBQ!'s Avatar
1. Order a JDM hammer like kaiba said
2. Find your Vtec solenoid on your valve cover
3. (Now you have to be very precise, or you could ruin the solenoid.) Line the hammer up with the diagonal line on the N on your valve cover
4. Pull the hammer back
5. Hit yourself in the face with it as hard as you can
6. Repeat step 5 as needed
7. ?
8. Profit.
Modified by OMGWTFBBQ! at 3:30 PM 1/4/2008
Old Jan 4, 2008 | 11:04 AM
kaiba's Avatar
Btw, you can buy your jdm hammers at http://www.jdmtools.com
Also rumors that your local AutoZone or Kragen carriers them too.
Old Jan 4, 2008 | 11:08 AM
Cln94EG1's Avatar
Be Careful with that JDM Hammer I hear those things have Vtec
Old Jan 4, 2008 | 11:29 AM
97Ej6mike's Avatar
If this isnt a joke, you dont deserve to drive a honda. I suggest looking into another car maker.
Old Jan 4, 2008 | 11:38 AM
homemadeturbo's Avatar
Default Re: (97Ej6mike)
˙ɯnʇɔǝɹ ɹnoʎ uı ʇı llɐʇsuı puɐ pıouǝlos ǝɥʇ ɟɟo ǝʞɐʇ noʎ ʎllɐɔısɐq
Old Jan 4, 2008 | 11:40 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (homemadeturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em1_fox &raquo;</TD></TR><TR><TD CLASS="quote">i know dat if u crack the solenoid it will hit hard and make vtec louder..my question is this..how would i crak the solenoid..wut would i need to do to make it hit hard and make it louder..any advice..
thank you..</TD></TR></TABLE>
VTEC doesn't crack... there is nothing you can do to the solenoid to make it "VTEC harder" because its just not possible.
Do you know what VTEC is, or how it works at all?
Old Jan 4, 2008 | 11:45 AM
ek-g6's Avatar
Damn another ricer strikes again!
Old Jan 4, 2008 | 11:48 AM
B16B_coupe's Avatar
HRD PKR
Default Re: cracking the solenoid? (ek-g6)
YOU CANT CHANGE HOW VTEC KICKS IN.
this has to be a joke. do some reading.
http://www.hondahookup.com/info/vtec.php
http://www.youtube.com/watch?v=AcT_ZyY3F0k
HOPE THIS HELPS YOU
The VTEC system in Honda engines allows the engine to have multiple camshafts.
It turns out that there is significant relationship between the way the lobes are
ground on the camshaft and the way the engine performs in different rpm(rotations per minute) ranges. To understand why this is the case, imagine that we are running an engine extremely slowly -- at just 10 or 20 rpm, so it takes the piston seconds to complete a cycle. It would be impossible to actually run a normal engine this slowly, but imagine that we could. We would want to grind the camshaft so that, just as the piston starts moving downward in the intake stroke, the intake valve would open. The intake valve would close right as the piston bottoms out. Then the exhaust valve would open right as the piston bottoms out at the end of the combustion stroke and would close as the piston completes the exhaust stroke. That would work great for the engine as long as it ran at this very slow speed.
When you increase the rpm, however, this configuration for the camshaft does not work well. If the engine is running at 4,000 rpm, the valves are opening and closing 2,000 times every minute, or thirty to fourty times every second. When the intake valve opens right at the top of the intake stroke, it turns out that the piston has a lot of trouble getting the air moving into the cylinder in the short time available (a fraction of a second). Therefore, at higher rpm ranges you want the intake valve to open prior to the intake stroke -- actually back in the exhaust stroke -- so that by the time the piston starts moving downward in the intake stroke, the valve is open and air moves freely into the cylinder during the entire intake stroke. This is something of a simplification, but you get the idea. For maximum engine performance at low engine speeds, the valves need to open and close differently than they do at higher engine speeds. If you put in a good low-speed camshaft, it hurts the engine's performance at high speeds, and if you put in a good high-speed camshaft it hurts the engine's performance at low speeds (and in extreme cases can make it very hard to start the engine!).
VTEC (which stands for Variable Valve Timing and Lift Electronic Control) is an electronic and mechanical system in some Honda engines that allows the engine to effectively have multiple camshafts. As the engine moves into different rpm ranges, the engine's computer can activate alternate lobes on the camshaft and change the cam's timing. In this way, the engine gets the best features of low-speed and high-speed camshafts in the same engine. Several of the links below go into the actual mechanics of the VTEC system if you are interested.
Several engine manufacturers are experimenting with systems that would allow infinite variability in valve timing. For example, imagine that each valve had a solenoid on it that could open and close the valve under computer control rather than relying on a camshaft. With this type of system, you would get maximum engine performance at every rpm range. Something to look forward to in the future...
Old Jan 4, 2008 | 11:53 AM
luvmihatch's Avatar
Default Re: cracking the solenoid? (B16B_coupe)
i wish i could put this whole convo in my sig but its too long. hahaha this just made my day.. omg i dont know what to say... but i wanna go by a jdm hammer.. one question tho do you have to hold it on the rite side. i herd they dont work rite if you dont.. thanks guys..
Old Jan 4, 2008 | 12:00 PM
B16B_coupe's Avatar
HRD PKR
I bet half the people in this thread dont even know how vtec works
mister_ej2
Dec 22, 2009 08:13 PM
HondamanXxX
Oct 9, 2007 05:05 PM
SiR Inspired ED7
15
Dec 19, 2005 08:10 PM
knoxville
Group Threads
Jun 27, 2005 04:06 PM
redteg1
10
Aug 18, 2001 08:47 PM
