Speedometer 5 MPH off - What in the world is causing this
hey - anyone can tell me why the speedo would be off 5 MPH on the high side ... the LS was an auto and i made it into a manual.
Ever since then the speedo/milleage is off by 5 MPH.
The tranny speed sensor is exactly the same - the dealer confirmed this. Any thoughts?
Thanks
Thanks
I don't think that's what it is - i calculated the overall diameter of the wheel pretty accurate with an calculator
http://www.miata.net/garage/tirecalc.html
195-55-15 vs. 205-45-16
gives a 0.8% difference - instead of 60mph - it reads 59.5 mph.
Not even close to 5MPH difference.
When I swapped an OBD I jdm gsr b18c1 w/ 5spd tranny into my '95 LS auto, I thought my speedo was off also. Never really confirmed it though.
I'm using a jdm P72 ecu and stock LS steelies w/ 195/60 R14s.
My gauge cluster is still the LS auto one.
What OBD is your teg? Are you using the auto gauge cluster?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stefanne3 »</TD></TR><TR><TD CLASS="quote">hey - anyone can tell me why the speedo would be off 5 MPH on the high side ... the LS was an auto and i made it into a manual.
blame the man in your avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI »</TD></TR><TR><TD CLASS="quote">
blame the man in your avatar</TD></TR></TABLE>
LMAO
LMAO
yes - the cluster is still the auto cluster - nothing's been changed on that.
I'm running an ODB I instead of ODBII - it was installed at the same time with the auto/manual conversion.
What instrumentation or method are you using to find your difference of reported vs actual speed? At what indicated speed are you noticing the difference?
Just for reference, my completely stock (stock engine, transmission, wheels, tires) 97 LS reads about 3-5 mph difference on those street radar signs that report your speed.
Lastly, does it matter if the speedo is 5 off? If it reads 5 mph over your current speed, just drive with the flow of traffic, or 5 mph over the posted limit according to your speedometer.
I'm actually comparing the speedometer reading on mine with cars going along side - you know those civics with digital speedos - easily readable from a different car next to them.
I've done several tests - including being on the phone with folks on the highway.
I did this because i was noticing a difference in the speedo reading while driving it without even getting an outside measurement - it just felt different ... and then i got it confirmed by doing these tests.
It's not really that i'm afraid i'm not going as fast as the speedo says i am - it's the fact that the miles are off by 10% also.
Both the total odometer reading and the manual one.
if you know your speedometer is off then you shouldn't be driving an integra
actually... i never noticed they came standard with them
I started this thread hoping to get some wisdom from some folks ...
but some of these comments on here are just an utter waste of time ... what a joke!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stefanne3 »</TD></TR><TR><TD CLASS="quote">I started this thread hoping to get some wisdom from some folks ...
but some of these comments on here are just an utter waste of time ... what a joke!</TD></TR></TABLE>
get used to it, there are a few that just like to make jokes instead of helping...
but i tested mine the same way and my speedo is off 7mph... part my problem is i have 17s w/ 215/40/17 tires, but i have am going to be trying a new speed sensor soon... i let ya know if that works... if ya fix yours be sure to post it though so i can try the same... good luck
From: Why To Steal My Car, NC, United States Of America
yes, rim and tire size affects the speedo , like my old toyota truck it had 35'' tires with 15'' rims and the speedo was wayyy off, my integra has tires that are a lil fatter than normal and my speedo is about 5-6 mph off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweek_boii »</TD></TR><TR><TD CLASS="quote">rims and tire size affect the speedo??? wow thats new for me</TD></TR></TABLE>
x2
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweek_boii »</TD></TR><TR><TD CLASS="quote">rims and tire size affect the speedo??? wow thats new for me</TD></TR></TABLE> are you expletiveing serious? yes rim and tire size affects the speedometer. it also affects braking. the bigger the wheels/ tires, the slower it accelerates, and the slower it deccelerates. to the op, maybe your speedometer is broken. i've read a bunch of people asking and trying to help, but all you say is no, thats ok, no, that wasn't touched, no no no.... if you want help, be open minded, if not... whatever dude.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhammond_82 »</TD></TR><TR><TD CLASS="quote"> if you want help, be open minded, if not... whatever dude.
for realz man i bet its just your tires,be open minded as guy above said
</TD></TR></TABLE>for realz man i bet its just your tires,be open minded as guy above said
