90-93 teg cluster in 92 95 civic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedNOTHARDLY »</TD></TR><TR><TD CLASS="quote">will it work or will i have to repin?</TD></TR></TABLE>
it will work, you have to cut the harness on both car the mate them up to work. too much wiring for me, look up in the search forum. this has been done before, some one has to have a write up.
You could get Fuel and Temp to work and the lights. As for speedo and mileage i believe they are cable VSS. You would have to convert to cable and drill a hole in the dash to make that work if im correct (85-90% sure)
Already told you...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote"> You would have to convert to cable and drill a hole in the dash to make that work</TD></TR></TABLE>
Yes the 90-93 Integra cluster IS cable so you will have to convert your tranny to a cable driven VSS instead of your electronic VSS that is in the car now. I was going to do the exact same thing until I realized that I have an LX with a 9000RPM redline tach already.
Mr. Giggles
Aug 11, 2006 05:21 AM
91CRXtreme
11
May 11, 2005 10:52 PM
