CRX fan not operating
I found a few threads about CRX fans not working but would there be a reason for it not to work on speed 1 and 2 on the dial? Mine recently stopped operating on those speeds but still work on the rest. It's pretty annoying having to use 3 and 4. Thanks.
Blower motor resistor, it's mounted on the blower motor topside, held in by two screws. You can see it if you remove the glove box, it has a 4-wire clip that runs into it. Get a new one and your problem is solved.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">Blower motor resistor, it's mounted on the blower motor topside, held in by two screws. You can see it if you remove the glove box, it has a 4-wire clip that runs into it. Get a new one and your problem is solved.
Awesome, thanks!
Modified by Topshot at 9:50 AM 1/4/2008
</TD></TR></TABLE>Awesome, thanks!
Nihilus
Jan 25, 2005 10:29 PM
