Suspension & Brakes Theory, alignment, spring rates....
Opinions Please- Rear Lower Tie Bar Clearance with ST Sway bars
Old Jan 4, 2008 | 04:27 AM
94b16coupe's Avatar
Default Opinions Please- Rear Lower Tie Bar Clearance with ST Sway bars
So yea, The ST sway bar bushings brackets that i installed do not clear the Neuspeed Tie bar that i currently have. I thought of an idea that may work. The tie bar needs .5" to clear the sway bar bushing bracket. So i was going to order a longer bolt and put a spacer in between the sub-frame and the tie bar. My only concern is strength and any chance of the bolt backing out. I drew up a diagram on what it will look like, let me know what you guys think...
Thanks,
Keith
Old Jan 4, 2008 | 05:22 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
The farther out the tie bar is from the subframe, the less effective it's going to be, although it's probably not doing all that much either way.
I would just get a different tie bar that will work with your sway bar setup if you're intent on having a tie bar under there.
honda_coupe
May 24, 2009 05:04 PM
Kyles ej1
Suspension & Brakes
Mar 27, 2005 12:17 PM
^Sammy]!.
Feb 7, 2004 08:15 AM
Zer0DazE
Jul 25, 2002 05:04 AM
ZUL8R
Aug 24, 2001 10:05 AM
