95 honda accord BRAKE LAMP PROBLEM
I have a 95 honda accord lx maual transmission my problem is that the brake lamp comes on when i press the brake while the car is on or the key ignition all the way, all my lights work from the rear and front my signals work my brake lights work i even bought new wiriring set for my taillights because when i bought it the old wiring set where all screw up and acted weird but never had that problem before.
1. i have new bulbs
2. new wiring set
3. all lights works
4. not the brake light the brake lamp that is next to the lights in the instrumental dash that turn on when u have a door open or trunk....
thanks
heres a picture so u guys can see what i mean!!!
<P>
1. i have new bulbs
2. new wiring set
3. all lights works
thanks
<P>
well the bulbs came with the new wiring set that i bought and its only the single socket ones, the old wiring set had the double socket one with the double filament i am not sure if the ones i have now has double filament
Well if you see inside the bulbs, it should have 2 filaments. And in the socket, it should have 4, thats right 4 leads. =D 2 leads for each filament.
amanda.hydar
Mar 10, 2013 12:02 PM
