trailing arm bushing homebrew remover?
Old Jan 3, 2008 | 09:45 PM
aimbot's Avatar
Default trailing arm bushing homebrew remover?
Hey all, i just got my energy suspension trailing arm bushings, but i dont have access to a remover, nor do i wish to order one for $115. Does anyone know if its possible to construct a makeshift remover or inserter? I appreciate any feedback. Thanks.
Old Jan 3, 2008 | 09:50 PM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
Default Re: trailing arm bushing homebrew remover? (aimbot)
are you talking about removing the inner bushing?? if so get a recp. saw and cut it out and get new bushings pressed in
Old Jan 3, 2008 | 10:14 PM
racebum's Avatar
Default Re: trailing arm bushing homebrew remover? (DOHCgarage919)
Can you just use a torch on these? I was thinking of ordering the same ones. On other cars i've used either propane or acetylene and just burned the little bastards out. Clean the metal with sand paper and you're good to go. Anything i should be aware of here before i go pyro?
Old Jan 4, 2008 | 04:02 AM
Dogginator's Avatar
Daisy... Daisy...
You can burn the rubber out of the bushings with a torch (propane or MAPP gas will work) and then split the outer sleeve with a hack saw assembled through the hole. Score it in two placed and tap the sleeve out of the arm.
emr88
Feb 20, 2011 05:29 PM
efyou999
Suspension & Brakes
10
May 28, 2010 09:12 AM
speed_demon018
Jan 14, 2009 06:55 PM
chatham
May 20, 2006 10:18 PM
Vinceg99
Nov 3, 2002 07:20 AM
