CEL code #9 cylinder sensor ?????
Old Jan 3, 2008 | 09:44 PM
skUnK2jdm's Avatar
Default CEL code #9 cylinder sensor ?????
Hey guys I have a 97 ek with a poorman type-r (gsr bottom,b16 head). And it has a sputtering problem! It idles fine but when you give it gas it sputters slightly. and iam also getting a cel( 9 CYP cylinder sensor )
what can the problem be? any suggestions will help thanks!
Old Jan 3, 2008 | 09:50 PM
Solster's Avatar
Default Re: CEL code #9 cylinder sensor ????? (skUnK2jdm)
i believe the cyp is part of the disty. you need a new one.
Old Jan 3, 2008 | 09:59 PM
skUnK2jdm's Avatar
can this cause the stutter?
Old Jan 3, 2008 | 11:28 PM
Solster's Avatar
if the sensor is going out it would cause it to studder. if the sensor is not working all the time it would tell the computer the car was at say idel one moment and say WOT the next changeing the timing and inj. pulse making the motor run lean then rich then leaen again causing the studder.
not that the cyp sensor does al that it would still be telling the computer that the motor is running diferent the the other sensors and it would try to make corection so that all the reading were with in tolerace.
Old Jan 4, 2008 | 06:18 AM
skUnK2jdm's Avatar
Default Re: CEL code #9 cylinder sensor ????? (Solster)
makes sense!
Old Jan 4, 2008 | 06:25 AM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
True, it does mean you need a new dizzy.
Old Jan 4, 2008 | 06:47 AM
gettin it's Avatar
Default Re: (phyzJunkieCivic)
Hey, replace the dizzy or get a new sensor bro. I fixed mine the other day.
Old Jan 4, 2008 | 07:10 AM
skUnK2jdm's Avatar
Default Re: (gettin it)
but is it causing it to stutter? because dizzys are expensive!! dont want to buy a new one if i dont have too
Old Jan 4, 2008 | 07:12 AM
If you can you can replace this thing that looks like a magnate with a single teeth that reads off the rotor in there. Dont know whats it called. Thats what we did to a friends car, and it works fine.
Old Jan 4, 2008 | 07:13 AM
Mr. Em1's Avatar
sounds like a dizzy, you can find a working one on the forum for about 100 or less depending on mileage and condition but if your trying to get new good luck ive seen them anywhere upwards to 300
Old Jan 4, 2008 | 07:32 AM
skUnK2jdm's Avatar
Default Re: (Mr. Em1)
ttt
Old Jan 4, 2008 | 07:37 AM
skUnK2jdm's Avatar
Default Re: (skUnK2jdm)
yea ill see if any1 local has one i can try out!
Old Jan 4, 2008 | 07:40 AM
hatch96y7's Avatar
distributor king has them for 140 on ebay
Old Jan 4, 2008 | 11:47 AM
skUnK2jdm's Avatar
Default Re: (hatch96y7)
ok will check them out!
Old Jan 4, 2008 | 11:57 AM
B16B_coupe's Avatar
HRD PKR
stick with OEM honda distributor man.
BTW: did it just start happening out of the blue? or after you did the swap?
If you have a extra known good cyp sensor sometimes you can switch it into yours ifyou know how to take a distributor apart.
Old Jan 4, 2008 | 12:51 PM
skUnK2jdm's Avatar
Default Re: (B16B_coupe)
deff will stick with oem!!
has any1 had this problem?
Old Jan 4, 2008 | 02:20 PM
Find another oem an take the cyp, lol make sure you solder it. LOL it said do not disassemble, when putting it back make sure it dosent hit the shaft.
Old Jan 4, 2008 | 02:31 PM
JDM-EJ698's Avatar
I've got one if you want it.pmed
Old Jan 4, 2008 | 02:34 PM
skUnK2jdm's Avatar
Default Re: (JDM-EJ698)
Old Jan 4, 2008 | 03:07 PM
skUnK2jdm's Avatar
anybody think it can be something else?
Modified by skUnK2jdm at 4:21 PM 1/4/2008
Old Jan 4, 2008 | 03:11 PM
mortificationrock's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skUnK2jdm &raquo;</TD></TR><TR><TD CLASS="quote">any think it can be something else?</TD></TR></TABLE>
NO! its your Dizzy!I had the same problem stuttered like hell and would even turn off on me,got the code 9 so i went to buy a new dizzy and Walla problem gone.Trust us its your dizzy,replace and your problem will be gone!
skUnK2jdm's Avatar
Default Re: (mortificationrock)
thanks thats what i wanted to hear!
Old Jan 4, 2008 | 03:22 PM
skUnK2jdm's Avatar
no1 was really sure on if that was the problem!
but deff will change out the dizzy
Old Jan 4, 2008 | 08:19 PM
skUnK2jdm's Avatar
Old Jan 4, 2008 | 08:36 PM
B16B_coupe's Avatar
HRD PKR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phyzJunkieCivic &raquo;</TD></TR><TR><TD CLASS="quote">Find another oem an take the cyp, lol make sure you solder it. LOL it said do not disassemble, when putting it back make sure it dosent hit the shaft.</TD></TR></TABLE>
make sure you solder what? do you have any clue on what your talking about?
the sensors are held in with srew's....
but yeah man replace the dizzy will be the best bet
only other thing it could be is wiring, i would check that first... on the dizzy and goin to the ecu, if you have a jumper etc
