JE pistons scat rods gsr block cranks and tons of misc.....
Old Jan 3, 2008 | 09:35 PM
SoSlo's Avatar
Default JE pistons scat rods gsr block cranks and tons of misc.....
KMS bronze valve guides(new never installed)______________$40(pending)
JE 81mm 9.0:1 compression with writst pins and locks________$200
Scat LS rods(spun bearing but still looks good)______________$70(pending)
GSR BARE BLOCK(NEEDS bore and deck)______________$30
b18c crank (need to be polished has 1 spun rod bearing)_______$50
type-r factory oil cooler________________________________$50
gsr tranny brace (2bolt)________________________________$10
gsr tranny brace(1bolt)_________________________________$10
gsr rear mount and pollyurathane incerts____________________$50
gsr driverside torque mount bracket_______________________$30
B SERIES KNOCK SENSOR__________________________$40
B SERIES COOLANT TEMP SENSOR__________________$30
B SERIES OIL PRESSURE SENSOR____________________$30
99 GSR WATER PUMP_______________________________$10
GSR INTAKE MANIFOLD BRACKET__________________$5
99 GSR WATER TUBE AND THERMOSTAT HOUSING____$15
b16 oil pickup_______________________________________$15
b series idler pulley(used)_______________________________$5
obd2 crank angle sensor________________________________$15
obd 2 timingbelt crank pulley(chipped)_____________________$5
obd 2 timingbelt crank pulley____________________________$5
obd 1 timingbelt crank pulley____________________________$15
3 gsr rods__________________________________________$10
3 usdm gsr pistons with wrist pins_________________________$10
2 jdm gsr pistons with wrist pins__________________________$5
obd1 coolant temp sensor(block)_________________________$5
b series coolant thermostat housing and tube_________________$15
4 oem b series wrist pin________________________________$5
type-r rear sway brackets(new in package)_________________$15(pending)
blue eg back seat____________________________________$15
92-95 climate control_________________________________$15
black small side dash defrost vents_______________________$5
painted red small side dash defrost vents(faded)_____________$2
painted red passenger side vent(faded)____________________$5
black interior door handle trim___________________________$10
painted black interior door handle trim(some small chips)_______$5
driverside black speaker cover__________________________$5
blue rear seatbelts____________________________________$10
both speaker covers(covered with black fabric)______________$10
b16 tranny brace_____________________________________$5
vx (13/16) brake master cylinder_________________________$5
srs computer________________________________________$1 5
ls crank case breather box______________________________$10
gsr crank case breather box_____________________________$10
gsr engine header bracket_______________________________$5
black charcole box____________________________________$5
5 bolt turbo exaust flange_______________________________$10
2.5"-3" turbo coupler__________________________________$5
2.5" t-clamp_________________________________________$5
3" t-clamp__________________________________________$5
picks on request
<FONT SIZE="18"><FONT COLOR="red">everything is OBO Need Cash Fast</FONT> </FONT>
THINGS I NEED ARE:
15" rims
CASH.....
i am paypal certified
hit me up at smmccurdy@hotmail.com
Old Jan 5, 2008 | 02:20 PM
Jett_07's Avatar
please send me pics of the JE pistons, KMS valve guides, and SCAT rods to da_integra_tuner@hotmail.com
also, are the pistons used, and what compression ratio are they when used in a b18a? Or, what is the JE part #? thanks!
very interested and have cash in hand! thanks
Old Jan 5, 2008 | 03:20 PM
SoSlo's Avatar
Default Re: (Jett_07)
email sent
SoSlo
Northern California (Sales)
Oct 28, 2007 02:54 PM
