93 octane hp?
Old Jan 3, 2008 | 09:32 PM
socallmechris's Avatar
Default 93 octane hp?
im gonna be building a b20vtec from the ground up. 93 octane is the highest available daily, so im thinking of between 11.5-12:1cr.
what kind of power are you guys making on 93 and how high are your compression ratios?
thanks
Old Jan 5, 2008 | 06:27 AM
nelsond's Avatar
Default Re: 93 octane hp? (socallmechris)
YOU NEED TO HAVE IT TUNED TO FIND OUT
Old Jan 5, 2008 | 06:45 AM
Boots's Avatar
11.6..195 pump gas
Old Jan 5, 2008 | 08:28 AM
bjones's Avatar
Default Re: 93 octane hp? (boots)
93 octane sounds good if you dont go any higher than 12:1 jus tune the **** out of it
Old Jan 5, 2008 | 02:32 PM
kevinz's Avatar
Default Re: 93 octane hp? (bjones)
11.5-11.7 ,,,,,,240.9WHP corrected
Old Jan 6, 2008 | 02:07 PM
X2BOARD's Avatar
I am getting away with mid 11's on really shifty 91 octane.... timing is a bish tho... mid 11 -12 should be doable on most 93's based on what I've seen.
Old Jan 12, 2008 | 05:13 AM
Default Re: 93 octane hp? (nelsond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nelsond &raquo;</TD></TR><TR><TD CLASS="quote">YOU NEED TO HAVE IT TUNED TO FIND OUT </TD></TR></TABLE>
really? i had no idea...
i was refering to after tuning and all that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevinz &raquo;</TD></TR><TR><TD CLASS="quote">11.5-11.7 ,,,,,,240.9WHP corrected</TD></TR></TABLE>
what kind of timing did you end up pulling if any?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X2BOARD &raquo;</TD></TR><TR><TD CLASS="quote">I am getting away with mid 11's on really shifty 91 octane.... timing is a bish tho... mid 11 -12 should be doable on most 93's based on what I've seen.</TD></TR></TABLE>
im aiming for between 11.5-12:1 but i dont wanna have to start pulling timing, thats just lost power. im aiming for around 250+hp with a b20vtec 2.2L stroker
Old Jan 12, 2008 | 08:13 AM
93-lsvtec-eh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by socallmechris &raquo;</TD></TR><TR><TD CLASS="quote">
im aiming for between 11.5-12:1 but i dont wanna have to start pulling timing, thats just lost power. im aiming for around 250+hp with a b20vtec 2.2L stroker</TD></TR></TABLE>
thats no small feat because if your want to keep it together long your already losing a thousand or so rpm you can turn the engine. so it has to make the power sooner without turning the **** out of it, but it can be done with that compression you just need the right combo of parts
Old Jan 12, 2008 | 08:46 AM
Default Re: 93 octane hp? (93-lsvtec-eh2)
i dont really expect the set up to last to 100k, ill be happy with more like 60k. its more of a "i bet i can do it" kinda thing that will be a fun toy till i kill it
Old Jan 12, 2008 | 01:05 PM
RG400SmartTowel's Avatar
go dyno
Old Jan 12, 2008 | 04:42 PM
16 to 20k would be more realistic. to make is last longer depending on wear you would want to pull it apart and check everything and re-ring it and slap in some new bearings to keep it going anywhere close to 60k
fo shizzle yo!
Honda Civic (2006 - 2015)
Apr 5, 2008 08:37 PM
dwojno
Nov 25, 2007 05:09 PM
spooncivic1
12
Nov 24, 2004 07:35 AM
magic hat #9
Apr 23, 2003 08:31 AM
7rrivera7
Apr 9, 2003 07:42 PM
