95 civic oil leak please help
Old Jan 3, 2008 | 08:48 PM
speedy_beedee's Avatar
Default 95 civic oil leak please help NOW WITH PICS
I have a 95 ex, i have oil on top of the tranny under the dizzy and v-tec selenoid. So far I replaced the dizzy o-ring but it didint help. when i took a second look i saw oil under the v-tec selenoid so i replaced the filter then ran the car. then it started leaking from the top part of the selonoid i replaced that gasket now it is still leaking from the top of the selenoid. i torqued all of the selenoid bolts to 9 pound feet thats what the service manual called for. if you have any thoughts please let me know.
Modified by speedy_beedee at 6:42 AM 1/4/2008
Old Jan 3, 2008 | 09:10 PM
philosofy1's Avatar
Default Re: 95 civic oil leak please help (speedy_beedee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedy_beedee &raquo;</TD></TR><TR><TD CLASS="quote">I have a 95 ex, i have oil on top of the tranny under the dizzy and v-tec selenoid. So far I replaced the dizzy o-ring but it didint help. when i took a second look i saw oil under the v-tec selenoid so i replaced the filter then ran the car. then it started leaking from the top part of the selonoid i replaced that gasket now it is still leaking from the top of the selenoid. i torqued all of the selenoid bolts to 9 pound feet thats what the service manual called for. if you have any thoughts please let me know. </TD></TR></TABLE>
have you replaced the cam seal on that side? did you tighten the valve cover gasket in sequence?
Old Jan 3, 2008 | 09:29 PM
Default Re: 95 civic oil leak please help (philosofy1)
no I havent replaced the cam seal, I have never taken cover off and its clean all around and under the cover. I will try and get pics up tommorow
Old Jan 4, 2008 | 05:41 AM
here is a link to the pics
http://s238.photobucket.com/al...mages
Old Jan 4, 2008 | 07:06 AM
newbietuner_si's Avatar
Default Re: (speedy_beedee)
cam seal had that same prob make sure that your oil isnt mixing with fuel. advice change it your self because taking it anywere they are going to rape you in labor.
Old Jan 4, 2008 | 07:50 AM
how can i tell if its mixing with the fuel, and why is there oil all over the top of the selenoid
Old Jan 4, 2008 | 08:32 AM
Syndacate's Avatar
IIRC the dizzy O ring just keeps oil from leaking through the inside of the dizzy, there's another gasket around it that keeps oil from leaking out in between the head and the dizzy (the outside of the dizzy).
It sounds like that's exactly what's wrong.
Old Jan 4, 2008 | 08:36 AM
well i replaced the o ring on the dizzy shaft and theres no oil in the dizzy cap.
Old Jan 4, 2008 | 08:39 AM
you can tell wen you pull your dip stick. smell it and look at it. its def noticable.
Old Jan 4, 2008 | 08:44 AM
also check the exaust if your blowing blue fumes you know
Old Jan 4, 2008 | 12:31 PM
no fuel in oil or blue smoke
Old Jan 4, 2008 | 02:33 PM
93egSLEEPER's Avatar
i JUST fixed this problem on my b16 last weekend. i thought it was the cam seal... took the head apart resealed it and still had the leak. took the VTEC solenoid off and woolaa there was a cracked gasket that was hard as a bullet letting oil by. went and bought a new solenoid gasket (comes w/ screen) and problem solved. the gasket was 15 bucks. give it a shot.
Old Jan 4, 2008 | 02:42 PM
random chaos 85's Avatar
Default Re: 95 civic oil leak please help NOW WITH PICS (speedy_beedee)
u said that its leaking form the top part of the solenoid? so, . . . is the solenoid itself bad?
Old Jan 4, 2008 | 03:55 PM
i cant tell if the solenoid is bad and i have replaced both the v-tec selonoid gaskets.
Old Jan 4, 2008 | 04:04 PM
Cln94EG1's Avatar
I had some problems like that with my Vtec Solenoid I tried like 4 different gaskets kept leaking and making me mad. Well Even though your NOT suppose to do it but I lightly but Gasket sealer around the edges not on the gasket and made sure it was real clean then put them back on and tighten everything back down and doesn't leak at all anymore
Old Jan 4, 2008 | 04:47 PM
thanks ill give that a try
Arolife
Honda Civic (2001 - 2005)
Apr 7, 2017 08:38 AM
BamaSkater09
Dec 8, 2013 04:24 PM
Sk8NJ91
Dec 3, 2012 06:56 PM
davey5300
May 7, 2010 06:01 PM
SonicRacing
Feb 28, 2009 07:20 PM
