Trouble with Quick Release! help asap
Old Jan 3, 2008 | 08:09 PM
KDL323's Avatar
Default Trouble with Quick Release! help asap
I tried to install a steering wheel on today on your 1996 Civic Dx (automatic) but you got stuck, the hub won't work and didnt fit because the SRS is in the way and when I tried to take off the SRS and one of the plugs didn't wanna come off.
PLEASE HELP ME ASAP! THANKS!
Old Jan 3, 2008 | 08:25 PM
crazyguy's Avatar
Default Re: Trouble with Quick Release! help asap (KDL323)
are u sure u get the right hub? here is how mine looks like with short hub and quick release hub and i remember i did remove that srs device, the one u are holding at last pic.
Old Jan 3, 2008 | 08:28 PM
KDL323's Avatar
Default Re: Trouble with Quick Release! help asap (crazyguy)
how did you get rid of the SRS device? pull it off? or?
Old Jan 3, 2008 | 08:32 PM
Luserkid's Avatar
If your not planning on running SRS just cut it. If you want to run it again trace the plug down to the source and you should be able to take it off there.
Old Jan 3, 2008 | 08:36 PM
Eran's Avatar
HT White Ops
Here's a thought:
UNPLUG IT AND REMOVE IT.
Old Jan 3, 2008 | 09:00 PM
KDL323's Avatar
i seriously dont feel like cutting it, but for some reason the plug wont come out. the one in the last picture.
Old Jan 3, 2008 | 09:01 PM
Eran's Avatar
HT White Ops
Default Re: (KDL323)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KDL323 &raquo;</TD></TR><TR><TD CLASS="quote">i seriously dont feel like cutting it, but for some reason the plug wont come out. the one in the last picture. </TD></TR></TABLE>
That's not the one you unplug. Follow it down under the dash near the steering column.
Old Jan 4, 2008 | 04:48 AM
crazyguy's Avatar
yeah i simply just cut it cause my oem steering wheel was out of the shape
Old Jan 4, 2008 | 06:38 AM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
Cut the thing, not like you have air bags on the new wheel. Trace the wires and remove everthing that the srs connected too.
Old Jan 4, 2008 | 09:04 AM
illusive's Avatar
Default Re: (phyzJunkieCivic)
Just work at it some more it is a pain to get at under the column. I see why there are so many hack job hondas out there.....ppl like to hack things off that can be unclipped
Old Jan 4, 2008 | 09:08 AM
Cln94EG1's Avatar
Default Re: (illusive)
Ya cutting that will set your SRS light now and that makes buyers think it was wreck so u have to be careful with that just trace down the plug and pull it off
Old Jan 4, 2008 | 09:13 AM
mattssi's Avatar
I wouldn't cut it if I were you.. If the car is ever valued again, that will surely affect it. It takes like 4 more minutes to remove it from under the dash. Have a little patience and do it the right way.
Old Jan 4, 2008 | 10:54 AM
KDL323's Avatar
im not going to cut it cause i think its a bad idea and my cousin thinks its a bad idea, so when he comes back, were going to find a way to trace it and pull it off.
Old Jan 4, 2008 | 11:05 AM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
U dont cut it, that plug wont come off. U have to trace those wires to under the dash and disconnect it from there. It should be mid way down the steering column
Old Jan 4, 2008 | 11:25 AM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KDL323 &raquo;</TD></TR><TR><TD CLASS="quote">im not going to cut it cause i think its a bad idea and my cousin thinks its a bad idea, so when he comes back, were going to find a way to trace it and pull it off. </TD></TR></TABLE>
Are you relly that lazy that you can't trace 2 feet of wire?
Old Jan 4, 2008 | 11:31 AM
ejoner's Avatar
Default Re: (Eran)
Its probably even less then 2 feet just remove as you go, I'm surprised you can pull a steering wheel but cant follow 2 wires. lol at auto with a "type R" shift boot.
Old Jan 4, 2008 | 11:38 AM
B16B_coupe's Avatar
HRD PKR
Default Re: (ejoner)
stop being lazy and trace the wires and remove them, gezzzz
Old Jan 13, 2008 | 09:04 PM
Agent_EM1's Avatar
Is this the ebay quick release kit?
Old Jan 13, 2008 | 09:09 PM
EG8R's Avatar
Default Re: Trouble with Quick Release! help asap (Agent_EM1)
It amazes how lazy some people can be... Or lack of common sense.
Ya I work on Honda's daily as my living but ****... Think before you do something. Don't just start pulling **** apart and taking stabs in the dark. And I hope you center that cable reel before you install it again... Or don't if you don't like money.
thatkid
Dec 31, 2009 10:29 AM
JDMFreak_DC2
Aug 20, 2009 08:26 PM
Jap_Spec_Imports
Oct 29, 2007 06:45 PM
dansaleen_04
Sep 10, 2006 05:58 PM
WhiteSlips
Nov 12, 2004 10:26 AM
