clutch and brake pedals to the floor
probably a stupid question
, but anyone know what the problem could be?
i searched several different things and never got a good answer
i was driving the other day and went to hit the brakes and the pedal went right to the floor. Now my clutch is doing the same thing, right to the floor
, but anyone know what the problem could be?i searched several different things and never got a good answer
Did you see if something is up with the pedals themselves??
If it looks ok then check your clutch cable cause thats the only thing attached to that pedal. Check your braking system for leaks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx »</TD></TR><TR><TD CLASS="quote">Did you see if something is up with the pedals themselves??
If it looks ok then check your clutch cable cause thats the only thing attached to that pedal. Check your braking system for leaks.</TD></TR></TABLE>
the pedals look ok(well ok for 20 year old pedals)
i'm gonna have the car looked at tomorrow
someone said something about a master cylinder, but idk
you powdercoat huh? hmmm
Modified by JRZ88DX at 11:25 PM 1/3/2008
97hb
Jul 23, 2002 04:13 PM
LSBeast
Apr 16, 2002 08:18 AM
