Suspension & Brakes Theory, alignment, spring rates....
Problem with a set of KYB shocks
Old Jan 3, 2008 | 05:31 PM
datssoled's Avatar
Default Problem with a set of KYB shocks
So I picked up a set of used KYB AGX shocks from a friend and all the shocks are in good working order except for one of the rear shocks. Since no springs are on them yet, I could push down and see the shock rods come back up. But for one of the rear shocks, it takes much longer for it to release and come back up. Adjusting the dampening of it works, but it still isnt releasing as fast as the other ones. Im pretty sure it isn't blown, but is there any way to get it to release quicker? I heard about some kind of lubricant that I could spray on it to make it release quicker. Any other suggestions?
Old Jan 3, 2008 | 06:30 PM
Targa250R's Avatar
be professional
Default Re: Problem with a set of KYB shocks (datssoled)
This really isn't a valid method of "testing" dampers.
Old Jan 3, 2008 | 07:38 PM
datssoled's Avatar
Yea I know but is there any types of lubricant I could put on so the releasing will become back to normal? or at least more smoother without lagging?
Old Jan 6, 2008 | 05:48 PM
datssoled's Avatar
should spraying WD 40 on the rod do the work?
bigdogadam
Jan 13, 2009 08:07 PM
AndyD
Jun 8, 2004 07:08 PM
AndyD
Mar 22, 2004 06:11 PM
lunchboxEF91
Mar 6, 2004 03:59 PM
FirstAdition1
Dec 2, 2003 07:22 PM
