NAME THAT SENSOR.......
Old Jan 3, 2008 | 02:22 PM
slowB20ej8's Avatar
Default NAME THAT SENSOR.......
quick question whats the sensor on top of the throttle body called oh yeah off of an integra ls
Old Jan 3, 2008 | 02:23 PM
slo_hatch's Avatar
Default Re: NAME THAT SENSOR....... (96lsivtech)
tps sensor i think.
ek-g6's Avatar
should be the map sensor?
Old Jan 3, 2008 | 02:25 PM
ek-g6's Avatar
heres a pic hope it helps.
B16B_coupe's Avatar
HRD PKR
Default Re: NAME THAT SENSOR....... (slo_hatch)
Its 100% the MAP sensor.
Old Jan 3, 2008 | 02:28 PM
slo_hatch's Avatar
Default Re: NAME THAT SENSOR....... (ek-g6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek-g6 &raquo;</TD></TR><TR><TD CLASS="quote">should be the map sensor?</TD></TR></TABLE>
yeah i got those 2 confused. my bad. lol on me!
Old Jan 3, 2008 | 02:32 PM
slowB20ej8's Avatar
ok......whats the sensor thats on the back of the intake manifold that coolant goes thru
Old Jan 3, 2008 | 02:33 PM
Cln94EG1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96lsivtech &raquo;</TD></TR><TR><TD CLASS="quote">ok......whats the sensor thats on the back of the intake manifold that coolant goes thru</TD></TR></TABLE>
Its Called take some dam pics or show us what your talking about cause theres a ton of sensors a motor
Old Jan 3, 2008 | 02:34 PM
ek-g6's Avatar
you are probably talking about the IACV
slowB20ej8's Avatar
Default Re: NAME THAT SENSOR....... (cln92eg)
aight *** hole
Old Jan 3, 2008 | 02:35 PM
B16B_coupe's Avatar
HRD PKR
as stated above IACV. btw dont be a ***** dude your the one asking for help.
ek-g6's Avatar
does it look something like this perhaps?
Old Jan 3, 2008 | 02:40 PM
Cln94EG1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96lsivtech &raquo;</TD></TR><TR><TD CLASS="quote">aight *** hole</TD></TR></TABLE>
Ya dude if u tried to do some work we could give u better answers faster. its called do some work were not going to feed them to u
Old Jan 3, 2008 | 02:42 PM
slowB20ej8's Avatar
yeah thats it.......ok little story so my car started thrown a check engine i checkd it and it was for the tps so i orderd a blox tps from jhpusa.com i replaced it and reset the ecu now its idleing like crazy....so asked my boi he said to check the IACV and make sure the screw didnt back out it was all good so i reinstalled it and then every thing went to hell still idleing high and now its thrown out hella white smoke from the exhaust like the head gaskets blown but i just replaced the head gasket less than a month ago......oh yeah and my radiator is smokn wtf is goin on with my car
Old Jan 3, 2008 | 02:44 PM
ek-g6's Avatar
have you tried cleaning the IACV? and have you adjust your idle? by turning the idle screw?
Old Jan 3, 2008 | 02:45 PM
slowB20ej8's Avatar
no i havent...........but would that solve the white smoke
Old Jan 3, 2008 | 02:47 PM
ek-g6's Avatar
is this when you first started the car in the morning or did it still blow white smoke after 10 mins or so? about your radiator im not sure maybe someone else can help.
Old Jan 3, 2008 | 02:48 PM
Cln94EG1's Avatar
Did U bleed your coolant system?
Old Jan 3, 2008 | 02:49 PM
slowB20ej8's Avatar
na its all the time now just started happening last night after i removed the iacv and reinstalled it
Old Jan 3, 2008 | 02:50 PM
slowB20ej8's Avatar
no should i have bleed the coolant
ek-g6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cln92eg &raquo;</TD></TR><TR><TD CLASS="quote">Did U bleed your coolant system?</TD></TR></TABLE>
x2
Old Jan 3, 2008 | 02:51 PM
ek-g6's Avatar
yes bleed it and see if your still getting the same symptoms.
Cln94EG1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96lsivtech &raquo;</TD></TR><TR><TD CLASS="quote"> no should i have bleed the coolant</TD></TR></TABLE>
Yes Thats a major step in changing a headgasket you might have blown another one
slowB20ej8's Avatar
do i need to bleed my coolant system
Old Jan 3, 2008 | 02:52 PM
slowB20ej8's Avatar
oh yeah i changed it at the time of the head gasket change.......thought u ment when i removed the iacv
