2.5 Bar Map sensor install issues
Old Jan 3, 2008 | 01:38 PM
stillsmokey's Avatar
Default 2.5 Bar Map sensor install issues
So i just installed my 2.5 bar, car starts, spikes to 2k rpm and dies. If i try to give it gas, it will rev up for a second, then will not respond.
Car is a obd0 Civic, b18b, running turboedit. If i use my old chip and stock map sensor, it runs perfect. I created a new whole new map from scratch for the 2.5 bar, and i also tried the church7.bin from the xenocron bin directory, both do the exact same thing.
Here is a pic of the sensor installed, incase i'm retarded and something looks obviously wrong
Here are the voltages with the Key On engine Off
Pin1=.2V
Pin2=Gnd
Pin3=4V
Is this thing expletiveed? Did i expletive up the install?
Any ideas would be great.
Old Jan 3, 2008 | 10:30 PM
ironcheftony's Avatar
Default Re: 2.5 Bar Map sensor install issues (stillsmokey)
i woould like to know as well, mine doesnt work worth of crap
Old Jan 4, 2008 | 07:32 AM
ncturbocivic's Avatar
Ohm out the pins with the sensor off the car wiring. I dont have my datasheet with me but the numbers should all be within a few hundred of each other. If you have one that is a 1000ohm and one that is 2000ohm, you ruined the sensor. Check this first, if everything looks well, then start a new basemap again.
Old Jan 4, 2008 | 08:32 AM
i guess mines messed up, with the ohm meter reading
20.4k and 1.54k ohms
ground on ground, and the other pin measuring the 2 other wires
Old Jan 4, 2008 | 09:38 PM
Default Re: (ironcheftony)
word, from pin2-pin1=21.8Kohms
pin2-pin3=1.4kohms
So i take it the thing is expletiveed? what could cause this?
Old Jan 5, 2008 | 02:07 AM
mtber's Avatar
Default Re: (stillsmokey)
It sounds like a tuning issue.
Check for a proper ground signal/5 volt power signal/output signal from the map sensor....
You should be reading a specific voltage at atmospheric pressure (look at the data sheet).
Old Jan 5, 2008 | 08:27 AM
Default Re: (mtber)
No, it's don't think it's a tuning issue, as i've tried dyno tuned maps for a setup identical to mine. I get the same result with the tuned maps, as well as my own basemap.
Old Jan 5, 2008 | 11:59 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stillsmokey &raquo;</TD></TR><TR><TD CLASS="quote">No, it's don't think it's a tuning issue, as i've tried dyno tuned maps for a setup identical to mine. I get the same result with the tuned maps, as well as my own basemap.</TD></TR></TABLE>
Ok, well check the sensor using the method I told you to :-)
Old Jan 6, 2008 | 10:12 AM
Default Re: (mtber)
In my original post i posted the voltage readings from each pin, this was at 0 psi obviously. Problem is, i don't have the data sheet, never came with one.
RiipTiide67
Engine Management and Tuning
Aug 23, 2011 03:54 PM
Civiclx
Nov 27, 2007 06:32 AM
EK k kay
Nov 2, 2006 01:04 PM
NA JDM GSR
Oct 29, 2006 08:38 AM
quickchris
Jul 28, 2006 09:47 AM
