help me choose camshafts...
Old Jan 3, 2008 | 12:24 PM
Slow_import's Avatar
Default help me choose camshafts...
just wondering which cams you guys would choose in my situation. the car is a 2000 civic si with the stock b16. right now the car has just the basic bolt on, 3 inch intake with a velocity stack at the end, skunk 2.5 exhuast, omni test pipe, jdm itr header, b&m short shifter, act stage 1 clutch, pp, fidanza fly wheel, hondata intake manifold gasket, prothane mount inserts. The car is converted to obd1 running a chipped p30 ecu.
what i want to order are skunk2 pro1 camshafts, camgear, skunk2 proseries intake manifold, and skunk2 dual valvesprings.
are the pro1's an over kill for my stock compression? (planning on tuning with crome.)
or should i go with just the stage 1's...
future plans are to swap in a gsr block with itr standard bore pistons or maybe p30's..
Old Jan 5, 2008 | 02:26 PM
ej_b16a's Avatar
Default Re: help me choose camshafts... (Slow_import)
you will need a lot more compression to use the pro 1's in a B16.
If you have stock compression you would be better of with skunk2 stage 1 or stage 2 tuner cams. Stage 2 will give you a better top end, but upgraded valvetrain is required.
Old Jan 5, 2008 | 02:35 PM
manoy's Avatar
Default Re: help me choose camshafts... (ej_b16a)
the tuner series ..
Old Jan 5, 2008 | 07:30 PM
Teamdiesel's Avatar
does anyone have dynos of the skunk2 stage 3 cams in action on a 1.8lt?
Old Jan 5, 2008 | 08:05 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: (Teamdiesel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teamdiesel &raquo;</TD></TR><TR><TD CLASS="quote">does anyone have dynos of the skunk2 stage 3 cams in action on a 1.8lt?</TD></TR></TABLE>
EH3SiGRL does. Her traps 109 mph.
https://honda-tech.com/zerothread?id=1666555
Old Jan 5, 2008 | 09:48 PM
H-EK22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej_b16a &raquo;</TD></TR><TR><TD CLASS="quote">you will need a lot more compression to use the pro 1's in a B16.
If you have stock compression you would be better of with skunk2 stage 1 or stage 2 tuner cams. Stage 2 will give you a better top end, but upgraded valvetrain is required.</TD></TR></TABLE> Pro1 He'll still see gains but not as much if he had higher compression, that he can do later... that way he wont have to get rid of the weak stage1 an purchase a more agressive cam.....but make sure you upgrade valve train an a vavle job an then you'll be getting good numbers
Old Jan 5, 2008 | 09:55 PM
quicksilver1689's Avatar
i ♥ snails
how about some buddyclubs or blox
Old Jan 6, 2008 | 03:58 AM
gsrob's Avatar
Hey, you should plan on getting the cams, valvesprings, retainers, injectors, and something like Hondata for the dyno tuning, unless you P30 comp can be retuned. What program are you running, all I see down there is that you made it OBD1. As fir a cam choice, I am running Blox b's (I believe the S2S2 equivalent). I'm really happy with them on my built gsr. If ya want to look at the graph it's in the dyno section of these forums. I believe it's the last page there.
boy_hapon
Aug 25, 2005 07:24 AM
DubyaAye
Aug 20, 2003 04:45 PM
Combustion Contraption
14
Aug 16, 2003 04:11 PM
gsr squirrel
Dec 6, 2002 07:44 PM
9d9GSR
May 19, 2002 10:06 PM
