FS: H22 longblock , H22 shortblock , H22 turbo manifold , Tanabe muffler
Here's more stuff from the racecar project i recently bought....
H22 head parts from the below engine.head casting is junk,most other stuff is good.cam caps,cams,VTEC solenoid,valve cover,etc....tell me what you need.$$
<U>SOLD!!!</U>Drag H22 turbo manifold.Great condition-no cracks or imperfections.$100:<U>SOLD!!!</U>
<U>SOLD!!!</U>Tanabe G Power Medallion muffler.had additional hangers welded on at some point.i cut them off and smoothed the can as best i could.shouldn't be able to see themarks when it's mounted on the car.$40:<U>SOLD!!!</U>
<U>SOLD!!!</U>H22A4 long block.stock internals....dropped a valve.head is basically useless.short block has a busted up piston.may be able to overbore the stock sleeve,or may need to be sleeved.perfect for somebody wanting a short block to build up.pictures to come later of the internal damage.missing lower timing belt gear and water pump.
$100 for the short block.PICK-UP ONLY!<U>SOLD!!!</U>
<U>SOLD!!!</U>H22 JDM short block.stock internals.i do have the windage tray and oil pickup to be included.missing the water pipe on the back of the block.$125
All prices do not include shipping.
located in Roanoke,VA.Paypal add 3%.
many vouches if needed.
THANKS
Chris
Modified by TeamNextGenChris at 10:02 PM 1/15/2008
Modified by TeamNextGenChris at 1:55 AM 1/17/2008
Modified by TeamNextGenChris at 7:37 PM 1/29/2008
Modified by TeamNextGenChris at 7:01 AM 2/1/2008
Modified by TeamNextGenChris at 5:14 PM 2/2/2008
[i]Modified by TeamNextGenChris at 5:15 PM 2/2/2008[/i
Modified by TeamNextGenChris at 5:17 PM 2/2/2008
Modified by TeamNextGenChris at 4:00 PM 2/4/2008
Modified by TeamNextGenChris at 8:38 PM 3/24/2008
ICK-UP ONLY!<U>SOLD!!!</U>All prices do not include shipping.
THANKS
Chris
added a set of 7",350lb,2.5" diam springs to my other FS thread.
Chris
Chris
update in the original post on the condition of the H22 longblock.
Chris
Chris
long block pics:
one bad piston.lots of crap in the other cylinders,but i think it may be able to be overbored and keep the stock sleeves.obviously,it can definitely be sleeved.crank looks good as far as i can tell.only problem looks to be the one rod and piston.great for somebody wanting to build a strong bottom end.
Thanks
Chris
Thanks
Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eggie75 »</TD></TR><TR><TD CLASS="quote">payment sent
got it..check your PM.
thanks
Chris
thanks
Chris
how much for the lower timing belt gear and the water pump and water pipe tube shipped to cincy ohio 45240
thanks
justin
thanks
justin
TeamNextGenChris
Feb 5, 2008 03:49 PM
