absolutely a true baller
the homie is truely a true baller, money comes up the baheeghans with him, so he asked me to help and im coming to ht for the source.
Car 1999 Honda civic si
baller status. b16a
Jackson racing S/c 12psi kit with hondata.. vtec @ 3500
ok he bought a vavletrain system for 1800 dollars like the baller that he is.
he claim that the vtec is disable for more oil pressure to the bottom of the block instead of the head.
now that this vavletrain was professinally installed the motor backfires like crazy. every stop and go it back fires. full throtttle it back fires. the hondata has a computer specially made for the sc system and he apparently installed incorrect camshafts could the ecu be the problem since vtec is actuating @ 3500 when the camshaft have no vtec to operate? what is this calling for? a re tune or a new ecu?
baller status. b16a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">ok he bought a vavletrain system for 1800 dollars like the baller that he is.
he claim that the vtec is disable for more oil pressure to the bottom of the block instead of the head.</TD></TR></TABLE>
and i don't even know what that means
ok i just got the word from him, he said the vtec is always working on the car, from idle to top end, theres no actuation between 5500. but since the ecm is programmed for the solenoid to work at 3500, why is it back firing then
ok if the vtec works all the time what happens to the vtec point that the ecm gives off?.. just sends a error? because the camshaft makes it work all the time
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bignewtCA »</TD></TR><TR><TD CLASS="quote">ok if the vtec works all the time what happens to the vtec point that the ecm gives off?.. just sends a error? because the camshaft makes it work all the time</TD></TR></TABLE>
the vtec point the ecm gives off now controls the flux capicitor, pretty easy change over, much more effective
Go out and buy some 0 ohm resistors, solder two leads together and put it inline on the hotwire for vtech..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bignewtCA »</TD></TR><TR><TD CLASS="quote">there is no way a true baller is going to disconnect a plug on his car. ecm error codes and rich/lean gas. </TD></TR></TABLE>
what?
what?
