help on coolant lines in throttle body...!!!!
Old Jan 2, 2008 | 08:54 PM
ls_bitik's Avatar
Default help on coolant lines in throttle body...!!!!
is it safe to bypass the coolant line in the throttle body? I have a obd1 ls throttle now in my car... and I want to use the obd2 gsr throttle body. the gsr doenst have the coolant thing under like the ls ones... im using the blox intake manifold for itr... lsvtec with stage one cams and p30 pistons.. help is appreciated
Old Jan 3, 2008 | 09:20 AM
98vtec's Avatar
moderator emeritus
Default Re: help on coolant lines in throttle body...!!!! (ls_bitik)
as long as the area you live in doesnt freeze, yes.
Old Jan 3, 2008 | 09:50 AM
ls_bitik's Avatar
Default Re: help on coolant lines in throttle body...!!!! (98vtec)
I live in San francisco.. it doesn't get that cold here. so do I just plug the small coolant line from the block going to the throttle body?
Old Jan 3, 2008 | 10:59 AM
4g hatch's Avatar
there should be to lines,one into the tb and one out of the tb.at least i think most are like that. anyway just go to hardware store and get you a barbed fitting and 2 clamps and run them together
Old Jan 3, 2008 | 12:47 PM
4dooritr's Avatar
Default Re: help on coolant lines in throttle body...!!!! (4g hatch)
I have both my IACV and TB bypassed for 4 years no problems
Old Jan 3, 2008 | 10:27 PM
ls_bitik's Avatar
Default Re: help on coolant lines in throttle body...!!!! (4dooritr)
ok thanks for the info guys!!
Old Jan 4, 2008 | 03:31 PM
Richard...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4dooritr &raquo;</TD></TR><TR><TD CLASS="quote">I have both my IACV and TB bypassed for 4 years no problems
X2
dougshatch
68
Jul 12, 2023 06:24 AM
EFstyle
Jul 29, 2008 06:40 PM
4DRmafia
Sep 3, 2005 10:17 AM
wanttorace
Jul 8, 2003 08:28 PM
