JDM B16A into integra LS help!
Well my B18B1 is burning oil due to rings and need to replace it. I want to get a B16A from HMO but I have some questions:
Which ECU do I need?
Since the B16A is OBD0 do I need to replace the distributor for an OBD1? If yes, can I use my B18B1 distributor?
Wiring harness, is it different from my B18B1?
Can I make it smog legal?
I'll appreciate if you guys can help, I need to know all the parts I need before perfoming the swap since it is my only method of transportation.
I have a obd1 B16 in my dd integra.
1. Run a JDM P30 ecu
2. Run a OBD1 B16/B18c1 Dizzy
3. Switch over your injectors from your LS and sensors and then you can use your harness just have to add vtec wiring.
4. I live in WI so we dont have smog!
hope this helps!
hope this helps!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDRETTI »</TD></TR><TR><TD CLASS="quote">doesnt HMO provide the harness and ecu with their swaps?? and it should be smog legal</TD></TR></TABLE>
I am pretty sure they do. It sounds like your new to this and no offence get help if you attempt the wiring harness, I tried to do it and nearly gave up on life lol....I hate the electrical end of working on cars
Im just getting the longblock so the P30 is around 200 bucks. I dont know about the harness though, Ill ask them about it.
Ok just to clarify, the distributor has to be from a b16a/b18c?
90da integra
May 20, 2014 02:18 AM
honda craz
Apr 11, 2008 02:34 PM
SuperRacerTypeR
13
Oct 5, 2005 07:48 AM
Luserkid
19
Nov 9, 2004 04:34 PM
