HELP... check engine light
Old Jun 29, 2002 | 07:20 AM
vtec-outlaw's Avatar
Default HELP... check engine light
Anyone know how I can get the damn light to go off. I have a 98' Civic DX and all that I have done so far is a AEM Cold Air intake and it goes off. Anyone else have this problem and know how to fix it????
Old Jun 29, 2002 | 10:21 AM
ptype's Avatar
Default Re: HELP... check engine light (vtec-outlaw)
reset ecu ! could be ur obd2 sensor not breathing well! check that best way to do it is to clean that sensor with choke cleaner
Old Jun 29, 2002 | 10:49 AM
Dr.Kimball's Avatar
Default Re: HELP... check engine light (ptype)
what code are you getting? THat could help a little.
Old Jun 29, 2002 | 12:10 PM
SuperRice's Avatar
Default Re: HELP... check engine light (Dr.Kimball)
IMO the easiest way to reset your ecu is open up your fuse box under the hood and pull out the radio fuse (7.5) for like 30 secs and then plug it back in. Your CEL should turn off. If it comes on again the chances are it's the O2 sensor. They are a bitch, I went through two of them already.
kaotic_ef
Dec 8, 2010 09:13 PM
boogie23
11
Nov 12, 2006 02:38 PM
HondaPH22
Jul 14, 2006 12:06 PM
sik26
Mar 19, 2005 08:02 PM
