Can Oil Pressure Switch do damage?
On my da my oil light comes on and its because of the pressure switch, now is that bad at all cuz if not i dont mind it, my oil levels are fine and i dont mind fixin it in a bit but i wanted to make sure that it wont be doing any damage to my motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vladd »</TD></TR><TR><TD CLASS="quote">you sure it's a bad switch, and not actually low oil pressure? just because the oil level is correct doesn't mean the pump is building enough pressure.</TD></TR></TABLE>
x2
do you have an aftermarket switch or anything? This is the reason I love my oil pressure gauge. In fact maybe you should get one
x2
I know my oil pump is good cuz the switch is actually a little loose theres slight movement to it. Also i can shut the car off and move the switch manually and the light actually turns off. When its on it flashes with the dips in the road.
