Installed: AP1 S2000 Steering Wheel
I just installed an S2000 Steering Wheel into my 1996 Accord LX Sedan. It works without a flaw into mine. I have heard the 94-95 Accord's are not compatible. I followed this DIY when I was installing mine (reference link below), and it worked perfectly. I have not wired the cruise control yet, so Im not sure if the DIY one is compatible as of yet. I will test it out the next time I have free time and I will keep everyone informed. Feel free to PM me or EMail ( TheNguGuy@***.Net ) with questions. I will try to answer them best I can.
Good Luck!!!
Link to DIY: http://www.ntpog.org/mods/fift...shtml
*** Cruise Control Update ***
I just installed the cruise control. Follow the DIY, it works perfect. The only difference is:
<U>Prelude Cruise Control Wiring Diagram</U>
GROUND
RESUME
SET
BLANK
<U>Accord Cruise Control Wiring Diagram</U>
BLANK
SET
RESUME
GROUND
It's upside down. Other than that, everything is the same. I hope this helps.
Modified by NGUSPEED at 8:55 PM 2/24/2008
Good Luck!!!Link to DIY: http://www.ntpog.org/mods/fift...shtml
GROUND
RESUME
SET
BLANK
BLANK
SET
RESUME
GROUND
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by awdgsx96 »</TD></TR><TR><TD CLASS="quote">That looks super good
Where did you find the steering wheel?</TD></TR></TABLE>
everything in working order would be pretty f-n bad *** ! def keep us updated on the cruise control.
I got the wheel off 51ludeguy here on HT. He has one left. PM him. He's a great seller.
I got the airbag off Craigslist locally for $75. I pieced everything together for less than $250
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oem_certified_accord »</TD></TR><TR><TD CLASS="quote">very clean, but what wheel swaps are available for the 94-95? prelude, CL, legend?</TD></TR></TABLE>
I am not sure what else is availible other than aftermarket wheels.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bird333 »</TD></TR><TR><TD CLASS="quote">Was your steering wheel off center at all like it was mentioned at the end of the write-up?</TD></TR></TABLE>
The steering wheel is off a notch like the write up states. It wont go on strait due to the spline. I haven't gotten an alignment yet. Usually the wheel being off bothers the heck out of me, but in this case, I dont really mind.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NGUSPEED »</TD></TR><TR><TD CLASS="quote">
Thanks for the info. I was just interested because I know they are a pretty rare item to find, I wouldn't put that on my CD5 haha. Hopefully someone who can really use it picks it up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I386 »</TD></TR><TR><TD CLASS="quote">Very nice job...Du ma
Du Ma, So Dep!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by naoandlata »</TD></TR><TR><TD CLASS="quote">Looks good
How big are they compared to RSX steering wheels? I hate the accord's thin, big wheels
They are the same size I believe or pretty close.
</TD></TR></TABLE>Du Ma, So Dep!!!
</TD></TR></TABLE>They are the same size I believe or pretty close.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeKe1point0 »</TD></TR><TR><TD CLASS="quote">
everything in working order would be pretty f-n bad *** ! def keep us updated on the cruise control.</TD></TR></TABLE>
Check out the Update ... The cruise control wurks!!!
can anyone verify that the splines on the 94-95 accords are different than the 96-97? apparently none of the aftermarket hubs fit on the 94s so i can get a race wheel on my race car. if the s2000 wheel will fit on the 94-95, then i could use a s2000 aftermarket hub and go from there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan »</TD></TR><TR><TD CLASS="quote">The splines are different.
There's a reason the s2k only fits on 96/97 and not the 94/95</TD></TR></TABLE>
What's up man.
And SRS system should still work assuming you wire up the airbag and what not correctly.
</TD></TR></TABLE>What's up man.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkimN »</TD></TR><TR><TD CLASS="quote">does the SRS still work?</TD></TR></TABLE>
I cannot definately confirm that the SRS works, but I can tell you that the SRS Light in the guage cluster does not come on, so that should be a really good sign that it is functioning correctly.
However, if anyone want's to test their set up and let us know, I am completely open to that too...
i need to check HT more often. well this sucks, so how in the hell do you get an aftermarket wheel on the 94/95 accords?
on weaksauce they have the whole combination kits for aftermarket wheels including hubs, quick release and steering wheel for one price. I am looking into getting the Momo Tuner series, the 350mm with the black w/ red stitching.
