Greddy turbo kit On Stock GSR 98
hey guys hows it going Newb here so please all help is apreciated.
Planning on getting the Bolt on Greddy turbo kit since it has a carb legal sticker and i live in cali. Also gonna get the intercooler kit and BOF.
My question is will a be able to throw on this kit on my car and go or will i need to buy some other stuff. My whole car is stock just i/h/e. Please let me know thanks alot
CARB legality is questionable on Greddy kits. With intercooler and BOV, it's not legal.
It will piggyback into your stock ECU and attempt to control the injection maps. You WILL need the extra harness to control the timing. I can't believe they get away with selling the kit without any control over the timing. It's actually a Mazda radio harness.
You're going to need a wideband O2 sensor and the Greddy USB-serial cable (this can be made for cheap) connected to a laptop in order to tune and not run on the super rich basemap.
Your intake and header go in the trash. The larger exhaust will help to spool the turbo.
alrigh so i also need the wideband sensor i know what that is
and the usb cable is it meant for tuning?
and what is this mazda radio harness?
sorry for all these ?'s
any other opinions thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupremexGSRx »</TD></TR><TR><TD CLASS="quote">and the usb cable is it meant for tuning?
The USB cable is for tuning and datalogging. You can make one or buy one. Check the Yahoo Emanage Group.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupremexGSRx »</TD></TR><TR><TD CLASS="quote">and what is this mazda radio harness?
The mazda radio harness just happens to fit into the eManage unit's second slot. I forget what year and make, but that info is available. It is used for creating timing maps (you will need to retard timing to prevent detonation which will destroy your engine). It has an ignition input and an ignition output.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_YANG »</TD></TR><TR><TD CLASS="quote">ur gonna need.... injectors...p28 ecu....thats about it, then my buddie can burn u a map for ur setup</TD></TR></TABLE>This would be referring to dumping the EManage altogether and tuning with a standalone ECU. A P28 will not work on a GSR without modification, as it does not have IAB control. You would need an OBD1 P72 ECU for your B18C1.
This is a good idea overall, and will give you much more control over your setup and tune, but you'll either need someone burn the bin's, or buy hardware to burn them yourself. You would also need to buy tuning software (or CROME Free) or pay someone to tune your car for you.
The kit should come with larger 310CC injectors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupremexGSRx »</TD></TR><TR><TD CLASS="quote">Doesnt the Emanage come pretune so i could use it until i tune it</TD></TR></TABLE>
Yes, you can, but it will not have any timing pulled and it will be extremely rich. It's good up to the stock wastegate setting of 5-6 psi.
Not only does it run your timing map like you are stock and not boosted (too much timing=detonation=bent rod/burnt piston). But in addition to that, because of the way the pggyback works, you are already shifted over in the timing maps by altering the map signal.
The wideband is the biggest $ hit there.
The harness is 5-10$ and emanage cable is either 5$ from radio shack (build it), 50$ from the internet (generic cable) or $100 from greddy.
If you're not up to it, pay someone to tune it for you.
how much psi can i run it until i Tune it which will be ASAP
i got some other questions bare with me please ha
Do the Greddy intercooler kits bolt on righ up the the turbo kit or do i have to buy something else
Also does the BOV bolt on to the greddy piping or does it get welded on.
Would it be better if i get a better fuel pump also?
Thanks alot for your help man
No problem, questions like these help the search engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupremexGSRx »</TD></TR><TR><TD CLASS="quote">how much psi can i run it until i Tune it?</TD></TR></TABLE>
0psi, as I said earlier, the basemap runs advanced timing and will take out your headgasket and possibly your block.
to Greddy for not providing a stock timing basemap or ignition harness. You can do run it for years at 5-6 psi, but when your coolant starts overflowing, then you will know why the ignition harness is needed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupremexGSRx »</TD></TR><TR><TD CLASS="quote">Do the Greddy intercooler kits bolt on right up the the turbo kit or do i have to buy something else?</TD></TR></TABLE>The greddy intercooler kits are usually a perfect fit for thier turbo kits. Very over priced, but each pipe is bent, cut and bead rolled perfectly.
Also does the BOV bolt on to the greddy piping or does it get welded on?</TD></TR></TABLE>You can either get a 6" peice of piping with a BOV flange, or you can just weld a flange onto the charge piping.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupremexGSRx »</TD></TR><TR><TD CLASS="quote">Would it be better if i get a better fuel pump also?</TD></TR></TABLE>The basemap is already way too rich, do NOT upgrade your fuel pump without being able to redcuce your injector duty. Also the upgraded fuel pressure doesn't work well with the piggyback engine managements, you will have hard starts and other issues related to running rich. CEL p0171 (Fuel trim too rich) is almost guranteed.
to Greddy for not providing a stock timing basemap or ignition harness. You can do run it for years at 5-6 psi, but when your coolant starts overflowing, then you will know why the ignition harness is needed.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupremexGSRx »</TD></TR><TR><TD CLASS="quote">Do the Greddy intercooler kits bolt on right up the the turbo kit or do i have to buy something else?</TD></TR></TABLE>The greddy intercooler kits are usually a perfect fit for thier turbo kits. Very over priced, but each pipe is bent, cut and bead rolled perfectly.
intgraCA
May 14, 2008 12:55 AM
