Fuel Cell Fabrication
Old Jan 2, 2008 | 10:42 AM
Justin Olson's Avatar
Default Fuel Cell Fabrication
Anyone around hear custom fabbed a fuel cell? I'm looking at building a large fuel cell for my 280z project that I will primarily be running on E85. I am just wondering how thick of material you guys have used on fuel cells. I'm thinking I will be using aluminum for the tank. I'm shooting for around 30+gallons without taking up the whole hatch portion of the car.
Justin
Old Jan 2, 2008 | 10:49 AM
k24em2's Avatar
Default Re: Fuel Cell Fabrication (Justin Olson)
http://www.fuelsafe.com/custom.htm
they use .063 or .100 aluminum sheet
Old Jan 2, 2008 | 10:58 AM
weiRtech's Avatar
OG Fabricator
i used .090" for the 2 stroke oil tank i posted a little while ago. i'm going to eventually be doing a fuel tank for my project car as well, but intend to add some baffles. something to consider if you might need them.
Old Jan 2, 2008 | 11:04 AM
redboost10's Avatar
Default Re: (weiRtech)
we used .090" on our fuel cell for our s2000 powered sandrail, as well as our 39 chrysler hotrod.
Old Jan 2, 2008 | 11:53 AM
Default Re: (redboost10)
Anyone have some pictures of custom fabbed tanks?
Regards,
Justin
Old Jan 2, 2008 | 01:33 PM
k24em2's Avatar
Default Re: (Justin Olson)
there are quite a few in the fuel safe catalog
Old Jan 2, 2008 | 02:12 PM
91TSiGuy's Avatar
I used 1/8" thick aluminum on this fuel cell I built 2 weeks ago.
Old Jan 2, 2008 | 03:20 PM
Flexer's Avatar
Default Re: (91TSiGuy)
Sounds like a couple people have chimed in with thickness.
Could you guys tell me what kinda of aluminum now?
3003 I would guess or what?
J. R.
Old Jan 2, 2008 | 03:25 PM
tony1's Avatar
Very nice 91TSI! I use .125" as well on my fuel cells. I like the idea of a fuel cell being a little stronger than it needs to be.
Old Jan 2, 2008 | 03:30 PM
Synapse Motorsport's Avatar
Default Re: (tony1)
Very well done, i dig it
Old Jan 2, 2008 | 04:48 PM
dave@passenger's Avatar
I use .125" as well. 5052 grade
Old Jan 2, 2008 | 06:58 PM
Bailhatch's Avatar
Default Re: (dave@passenger)
I have only done 2. Both were .125" 5xxx
Old Jan 2, 2008 | 07:28 PM
KFMRC's Avatar
at 30 gallons I would seriously consider building 2 seperate tanks. 1/8 5052 material as a min for sure. we have used whiffle ***** in the past for baffling in alky for poly circle track car tanks but not sure about how they hold up with e85 a single 30 gal tank will need some baffles for sure and a good design to keep from splitting the seams
Old Jan 5, 2008 | 06:00 AM
manifoldmiketyson's Avatar
Default Re: (KFMRC)
6061 using a 4043 rod. you want a little flex over strength. i agree with the .125 wall, not to mention its a lot of fun to weld.
Old Jan 5, 2008 | 04:53 PM
all_motor_mike's Avatar
Default Re: (manifoldmiketyson)
what is the ideal type of aluminum to make a fuel cell/tank out of? ive always used 6061 and either 4043 or 5356 rod for everything ive ever made.
mike
Old Jan 5, 2008 | 05:13 PM
91TSiGuy's Avatar
Default Re: (all_motor_mike)
With my fuel cell above, I used 3003 aluminum. Here's some facts on it:
http://www.suppliersonline.com...3.asp
TypeRobert
Sep 9, 2006 02:06 AM
jj07
Apr 14, 2006 07:52 AM
azzenco
Jan 14, 2003 05:15 PM
