Upper control arm hitting
Old Jan 2, 2008 | 10:31 AM
aries331's Avatar
Default Upper control arm hitting
So I replaced my driver's side upper control arm and now it's hitting against the inside of the fender. My car is lowered like 1.2 inches. It only does it when I hit a bump or something. I had the car aligned and it still hits. I have an adjustable camber kit. It looks like it is pointing way up then normal, compared to the other side. The right right side is ok. Is there a way to correct this problem? If the right side is ok, shouldn't the alignment shop be able to bring it to the same specs as the right side so it doesn't hit? Are the two sides alignment specs the same?
One more question: can shaving the arm cause problems to it. I did before and I think that's why my ball joint was busted. Am I better off without a freaking camber kit?
Modified by aries331 at 3:07 PM 1/2/2008
Modified by aries331 at 11:29 PM 1/2/2008
CRX 2.0V-T
Dec 19, 2006 12:00 PM
DaChoZn1
May 15, 2005 07:57 PM
down_the_hatch
10
Feb 17, 2005 06:40 AM
DeLiRiOu5
Oct 7, 2003 05:04 AM
patastinky
Jun 17, 2003 02:44 PM
