K20 + jun cams + 15 CR pistons - what valvetrain and valve size?
Old Jan 2, 2008 | 01:26 AM
itr_18's Avatar
Default K20 + jun cams + 14 CR pistons - what valvetrain and valve size?
Hi,
setup: Sleeved and bored K20 + Jun K cams + Wiseco 13.7 CR Pistons.
We want to rev high.
Now we want to make head - What size of valves should we use? Only stock size or oversized are possible?
thanks.
JUN cams specs here:
INT::#1 (Pri): DUR 61(244) LIFT 8.2 --- #2(Mid): DUR:78(312) LIFT 12.5 --- #3(2nd)DUR 60(240) LIFT7.5
INT::#1 (Pri): DUR 62(248) LIFT 8.5 --- #2(Mid): DUR:78(312) LIFT 12.5 --- #3(2nd)DUR 61(244) LIFT7.8
Modified by itr_18 at 4:52 PM 1/2/2008
Old Jan 2, 2008 | 10:41 AM
4piston's Avatar
Default Re: K20 + jun cams + 14 CR pistons - what valvetrain and valve size? (itr_18)
Stewart Racing Engines
317-244-9129
Talk to Josh and he will be able to point you in the right direction. If phone contact is a problem, drop me an email at vtecluke99@aol.com and I can give you a hand on K heads.
itr_dc2
18
Feb 22, 2005 03:30 PM
J2turbo21
Mar 3, 2003 01:21 AM
topspeed86
Feb 6, 2003 06:40 PM
96SR-V
Jul 23, 2002 08:31 AM
