steering rack is humming, can anything be done besides replacing the rack?
Old Jan 2, 2008 | 12:11 AM
vladd's Avatar
Default steering rack is humming, can anything be done besides replacing the rack?
my steering rack has started making a humming noise when turning. it started when i had ps taken out, now i've put ps back in and the noise is still there. can anything be done to the rack besides replacing it?
Old Jan 3, 2008 | 07:55 PM
vladd's Avatar
Default Re: steering rack is humming, can anything be done besides replacing the rack? (vladd)
Old Jan 3, 2008 | 08:26 PM
blkb18's Avatar
When you pulled the ps did you run some lines from the rack to a resivoir with fluid or did you just loop the line? Sounds like you may have damaged the rack from lack of lubricant.
Old Jan 4, 2008 | 01:26 PM
vladd's Avatar
Default Re: steering rack is humming, can anything be done besides replacing the rack? (blkb18)
yeah i had the lines t'd to an extra clutch resevoir. my brother still has the exact same setup in his integra and his rack isn't making any noise.
Old Jan 4, 2008 | 02:13 PM
GserpleaSR's Avatar
Sounds like a bad rack.
PinoyDelS0l
Suspension & Brakes
Dec 10, 2009 07:59 PM
davidluko
Aug 31, 2006 07:16 PM
JDM SLICK
Suspension & Brakes
17
Feb 14, 2006 10:20 AM
mtber
Dec 4, 2003 05:05 AM
