Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Effects of installing top hats on suspension set up
Old Jan 1, 2008 | 09:26 PM
BRN12345's Avatar
Default Effects of installing top hats on suspension set up
I have been trying to sort out my suspension setup for a while now and have not been able to get it to where i am like it. I am running GC top hats on the front suspension only and no top hat on the back.
When running top hats, do they have to be on all 4 corners or is front only ok?
Old Jan 1, 2008 | 10:04 PM
jeffy's Avatar
Default Re: Effects of installing top hats on suspension set up (BRN12345)
if you are referring to the extended versions, fronts only is usually fine and i think most people only run them on the front. the rears dont need extended top hats because they have enough travel/less weight and dont bottom out under severe load like the fronts do. thats how my car is set up and im perfectly happy
Old Jan 1, 2008 | 11:14 PM
Jeff_B's Avatar
Default Re: Effects of installing top hats on suspension set up (jeffy)
I am also running GC top hats on the front only and it's been working great. What specifically don't you like about your setup?
Old Jan 2, 2008 | 08:27 AM
climb_on's Avatar
i also run them in the front with no problems, like stated already, my worries is with bottoming out in the front not the rear. also i run my car with a staggared stance and the front is lower.
Understeer
Suspension & Brakes
11
Apr 28, 2006 07:19 AM
SiR Inspired ED7
Jul 7, 2005 11:55 PM
allmota1.8
Jun 13, 2004 01:45 PM
k279
28
Jun 2, 2004 10:17 AM
CW_97_ITR
May 29, 2003 09:49 AM
