NEED help Dash info
Old Jan 1, 2008 | 08:49 PM
DiMpL3s's Avatar
Default NEED help Dash info
im having a problem with my gauge cluster not lighting up.... i checked the fuses and even changed out the cluster and i still have no lights...
also im going to be swaping out my tan dash with a black one..
kinda wondering if anyways has the good'OL pdf file of he repair manual...
can someone help me out.. need all the diragrams and crap....
thanx
HT 4LiFe
TTT
Old Jan 1, 2008 | 08:56 PM
mike9571's Avatar
Default Re: NEED help Dash info (DiMpL3s)
Your dimmer switch is probally broken. Or your dimmer switch relay.
Old Jan 2, 2008 | 12:29 PM
DiMpL3s's Avatar
Default Re: NEED help Dash info (mike9571)
IF THE DIMMER OR THE RELAY IS BROKEN THEN Y EVERYTHING ELSE LIGHT UP...
THE CLUSTER IS THE ONLY THING OUT NOT THE CLIMATE CONTROLS, RADIO OR MY AUTOMATIC CONTROLS.....
ANY ONE ELSE????
Old Jan 2, 2008 | 01:25 PM
weavertime1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike9571 &raquo;</TD></TR><TR><TD CLASS="quote">Your dimmer switch is probally broken. Or your dimmer switch relay.</TD></TR></TABLE>
Mine did the same thing and low and behold it was the dimmer switch!
Old Jan 2, 2008 | 02:25 PM
mike9571's Avatar
Default Re: NEED help Dash info (weavertime1)
easy killer turns your caps off.
Get a voltmeter and check to see if you getting power from the plugs.
Old Jan 2, 2008 | 06:55 PM
DiMpL3s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike9571 &raquo;</TD></TR><TR><TD CLASS="quote">easy killer turns your caps off.
caps are on allways at the computer at my work... ment nothing by it...
just looking for the service manual from acura in a pdf file.... i got it once but my laptop took a crap...
Old Jan 2, 2008 | 10:44 PM
HONDRETTI's Avatar
maybe you swapped in a cluster with broken bulbs?
Get a voltmeter and check to see if you getting power from the plugs.</TD></TR></TABLE>
Old Jan 3, 2008 | 09:03 PM
DiMpL3s's Avatar
Default Re: NEED help Dash info (HONDRETTI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDRETTI &raquo;</TD></TR><TR><TD CLASS="quote">maybe you swapped in a cluster with broken bulbs?
no came outa a working gsr (my buddy put a type r in his gsr the day before)
anyone with the service manual??
Old Jan 3, 2008 | 09:06 PM
aaronISthrowed's Avatar
Do your taillights and park lights still work?
Old Jan 5, 2008 | 01:53 PM
DiMpL3s's Avatar
Default Re: NEED help Dash info (aaronISthrowed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronISthrowed &raquo;</TD></TR><TR><TD CLASS="quote">Do your taillights and park lights still work?</TD></TR></TABLE>
Yes every light is on inside and out of the car. but the gauge cluster doesn't light up thanx
tTt
Old Jan 5, 2008 | 02:16 PM
northemt88's Avatar
pull your cluster and check the bulbs and the clips into the cluster
Old Jan 5, 2008 | 10:19 PM
DiMpL3s's Avatar
Default Re: (northemt88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by northemt88 &raquo;</TD></TR><TR><TD CLASS="quote">pull your cluster and check the bulbs and the clips into the cluster</TD></TR></TABLE>
not the cluster....
please delete no help on integra thread!!!!!!!!!!
Old Jan 6, 2008 | 01:36 AM
Naruto's Avatar
Default Re: (DiMpL3s)
You had a very good suggestion, but you chose to ignore it. I also had a similar issue, but it was the dimmer switch that I had to replace. Take it for what it's worth, but if you're not willing to at least try it out, then no one else is going to be able to help you. Also, keep in mind that a service manual may not necessarily give you the info you need. Simple troubleshooting will be your greatest asset......most of the time.
Old Jan 6, 2008 | 01:29 PM
94 IntegraLS's Avatar
Default Re: (Naruto)
Heres a pdf file on how to remove the dash http://www.in.honda.com/Rjanis...A.pdf
Old Jan 6, 2008 | 06:18 PM
tweek_boii's Avatar
Default Re: (94 IntegraLS)
bump i have same problem and need solution!!
Old Jan 6, 2008 | 11:32 PM
DiMpL3s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94 IntegraLS &raquo;</TD></TR><TR><TD CLASS="quote">Heres a pdf file on how to remove the dash http://www.in.honda.com/Rjanis...A.pdf</TD></TR></TABLE>
hey man thanx for the pdf file and it would have been helpfull if i came home yesterday and checked my post after work but i headed straight to my friends house and we ripped out my tan dash and installed the black one i picked up 2 weeks ago and everything came out good but still no lights on the cluster....
do u have the full file for a download??
xxjasonxx
Nov 20, 2008 06:08 PM
pinoy2o9
Nov 3, 2008 09:22 PM
R-81DC2
Mar 4, 2006 10:18 PM
whiteef-8
16
Feb 24, 2005 05:45 AM
deez nuts
13
Apr 29, 2004 11:04 PM
