help please!!!!!
Old Jan 1, 2008 | 08:44 PM
vtecsi00's Avatar
Default help please!!!!!
i recently finished my build and i am trying to start my car now... But for some reason it doesn't want to start??? Any ideas????
Old Jan 1, 2008 | 09:23 PM
racebucket_eg's Avatar
Default Re: help please!!!!! (vtecsi00)
Have you checked fuel and spark? Is it turning over and just not cranking?
Old Jan 2, 2008 | 07:37 PM
vtecsi00's Avatar
Default Re: help please!!!!! (racebucket_eg)
it has fuel and spark...... i took out plug 1 and it smelled of gas. we checked spark.
Cams are at tdc. distributer cap is pointing to number 1
Old Jan 2, 2008 | 08:12 PM
vtecsi00's Avatar
there is no back fire... it seems like a timing issue??? but not positive. asking for some help please. would love to drive my car again... it has been a year in a half
Old Jan 2, 2008 | 08:17 PM
What about your mechanical timing?
Old Jan 3, 2008 | 06:49 PM
vtecsi00's Avatar
i talked to my builder and he put the skunk mark on the top instead of the degree marks up top on the cams. so i am 180 off. hopefully he is right with his memory. will find out on saturday when i try to start it again!!!!!
Old Jan 13, 2008 | 04:34 PM
vtecsi00's Avatar
I turned the distributer 180 degree's and it still won't start. Oh this is so frustrating.
any help would be appreciated.
Old Jan 13, 2008 | 07:08 PM
spun Vtec's Avatar
Go back to basics, Check fireing order, run a compression test...
If you are getting spark and fuel and its not starting or backfireing its prob a dizzy problem. That or the motor dosnt have compression. Are they new plugs?
Your going to have to give more info if you want more imput from others.
Old Feb 23, 2008 | 09:05 PM
vtecsi00's Avatar
so the cams ended up being not at top dead center. so we fixed that and it started right away. But the bad news was that while we were driving it it died. It seems that the builder didn't install the inner and outer piece that keeps the timing belt from coming off !!!!!! So the car died, pushed it back home and now i have to take it apart and hope that i didn't ruin any valves....My luck
Old Feb 23, 2008 | 09:20 PM
all-mtr-teg's Avatar
Have your builder fix it, that's a bullshit mistake.
Old Feb 25, 2008 | 06:44 PM
vtecsi00's Avatar
Default Re: help please!!!!! (all-mtr-teg)
it is a bullshit mistake. I took everything apart and the belt is just fine, it didn't jump time, there was a lot of melted plastic (timing cover). With all that said i am mad, but i am also glad in a way that nothing is wrong with my motor!!!! A lesson learned the hard way
91daINTEGRAda91
Apr 5, 2008 04:32 PM
Auby
Jan 18, 2007 07:26 AM
XJamesX
13
May 29, 2006 10:10 PM
thunteg
Sep 10, 2004 11:54 AM
KooK
Apr 12, 2002 08:27 AM
