antenna won't go up
So I recently got into the integra scene ('94 ls) and the antenna was working fine. Sometimes struggling/making noise when going up and down, but worked. Well i installed a new head unit and guess what. Now it wont go up when i turn on the car/ radio. Anyone had this happen before? Can people maybe let me know about things to check? Thanks for any help.
not sure. All i did was use the harness that was for my eg. Theres a antenna turn on lead? i did plug in the antenna cord... the one that seperately plugs into the head unit.
my antenna wont go down
when i turn on the radio it makes noise as if its going up then when i turn it off it make noise like its going down
never really looked to much into it
but now i might check it out in the morning
If the motor makes noise and there is no motion, the plastic cable is most likely damaged and you need a new mast.
If nothing happens, yes there is an antenna turn-on lead. It is typically blue in aftermarket radio harnesses.
my 90 teg antenna broke too, it makes the same noise, but its stuck half way so it doesn't looks so bad, been like that for 2 years now.
