ground VTEC solenoid?
Old Jan 1, 2008 | 06:16 PM
EJuno's Avatar
Default ground VTEC solenoid?
can u ground the VTEC solenoid, to make VTEC crack louder?
Old Jan 1, 2008 | 06:18 PM
SIRIUS's Avatar
Default Re: ground VTEC solenoid? (EJuno)
Yes.
Old Jan 1, 2008 | 06:20 PM
GoodEyeSniper's Avatar
86%
Default Re: ground VTEC solenoid? (SIRIUS)
Indeed. Mine, in fact, cracks Mad hard.
SilentEdge's Avatar
Batpool
And thus the 08s begin.
Senses Fail y0!'s Avatar
I should know better
Default Re: ground VTEC solenoid? (GoodEyeSniper)
Of course.
Old Jan 1, 2008 | 06:24 PM
Micha's Avatar
FAILWGN
Default Re: ground VTEC solenoid? (Senses Fail y0!)
Only if its triple ported.
Old Jan 1, 2008 | 06:32 PM
ProjectDarkBlack's Avatar
Default Re: ground VTEC solenoid? (micha)
drill a hole in your solenoid. That made mine hell of loud
Old Jan 1, 2008 | 06:46 PM
SilentEdge's Avatar
Batpool
Also it might be a good idea to turn up the boost on your VTEC so you have more horses. That way it will crack super loud and you should be able to chirp the tires all the way through third!
Old Jan 1, 2008 | 06:55 PM
jdmturbo1127's Avatar
Just be sure that its ground direct to the battery. And also, if you REALLY want to get the most crack out of it, put a vtec controller on it and set it to engage at 3,000 rpms
Old Jan 1, 2008 | 06:57 PM
black cx's Avatar
Default Re: (SilentEdge)
port the vtec solenoid
Old Jan 1, 2008 | 07:01 PM
ipleadthe5th's Avatar
Photoshop Guru
Default Re: (black cx)
Be sure to cross drill your break lines before attempting to ground your ported solenoid or no crack.
Frickr's Avatar
Default Re: ground VTEC solenoid? (jdmturbo1127)
ok call me a dumbaas if you want but how would grounding the solenoid make it hit harder?
Old Jan 1, 2008 | 07:03 PM
sicky's Avatar
grammer nawzi
Default Re: ground VTEC solenoid? (Frickr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frickr &raquo;</TD></TR><TR><TD CLASS="quote">ok call me a dumbaas if you want but how would grounding the solenoid make it hit harder? </TD></TR></TABLE>
And the 07's are still living up to their expectations.
Old Jan 1, 2008 | 07:04 PM
Default Re: ground VTEC solenoid? (sicky)
the magnet hits the casing harder, duh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicky &raquo;</TD></TR><TR><TD CLASS="quote">
And the 07's are still living up to their expectations.</TD></TR></TABLE>
Did you expect anything more?
Old Jan 1, 2008 | 07:05 PM
sicky's Avatar
grammer nawzi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Senses Fail y0! &raquo;</TD></TR><TR><TD CLASS="quote">
Honestly, no.
Old Jan 1, 2008 | 07:07 PM
black cx's Avatar
https://honda-tech.com/zerothread?id=2033900
Old Jan 1, 2008 | 07:14 PM
.Beaver's Avatar
Bloody Beaver
A grounded vtec solenoid makes your hampster run faster.
Old Jan 1, 2008 | 07:17 PM
Frickr's Avatar
Default Re: ground VTEC solenoid? (.Beaver)
thats what i thought.. little drunk right now so takes a it morr to sniff through all the
Old Jan 1, 2008 | 07:48 PM
sicky's Avatar
grammer nawzi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frickr &raquo;</TD></TR><TR><TD CLASS="quote">thats what i thought.. little drunk right now so takes a it morr to sniff through all the </TD></TR></TABLE>
Your attempt at saving yourself by suddenly misspelling words and blaming it on alcohol has failed.
Old Jan 1, 2008 | 07:55 PM
Frickr's Avatar
its not that i got a tablet pc ttyin to type with an onscreenkeyboard the letters that are right next to each other dont always work its not really alcohal just dont know the rules on other illegal activities
Old Jan 1, 2008 | 08:08 PM
Mcdc2's Avatar
Bwahahahahahaha!!! Just as we expected the 08's to be. Go for it and ground your solenoid and let me know how it goes!
Old Jan 1, 2008 | 08:18 PM
Coach McGuirk's Avatar
who peed in my canteen!?
Default Re: ground VTEC solenoid? (Mcdc2)
define "crack louder" ?
Old Jan 1, 2008 | 08:21 PM
Folgers's Avatar
Default Re: ground VTEC solenoid? (Coach McGuirk)
I grounded mine to the plus on the battery.
Old Jan 1, 2008 | 08:29 PM
EK_B's Avatar
Default Re: ground VTEC solenoid? (Folgers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Folgers &raquo;</TD></TR><TR><TD CLASS="quote">I grounded mine to the plus on the battery. </TD></TR></TABLE>
LOL
