Distributor on a zc
From what I can tell, the TD-48U is the same as the TD-42U, so I'm assuming you have an OBD-1 SOHC VTEC ZC. Thus, you will need a distributor from a D16Z6 which is found in the USDM '92-95 Civic EX & Si, and '93-95 del Sol Si.
Do obd-1 distributors have two connections on them because the one i have has one connection, does that mean its an obd-2 distributor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramos2589 »</TD></TR><TR><TD CLASS="quote">Do obd-1 distributors have two connections on them because the one i have has one connection, does that mean its an obd-2 distributor.
it only has 1 plug?? is it round or square?
freshly boosted DOHC ZC
Jan 12, 2007 11:50 AM
BoostdRex
16
Nov 26, 2005 11:39 AM
48u, 95, connection, connector, d16z6, distributor, distriubtor, honda, td, td42u, td48u, two, work, zc
