Je pistons stamped 87m under the crown is this the bore it is inteded for?
Old Jan 1, 2008 | 04:10 PM
jetlude's Avatar
Default Je pistons stamped 87m under the crown is this the bore it is inteded for?
Its an H22, and this 87m stamp can be seen on each piston looking up from the oil pan.
Would it be safe to assume that these are 87mm pistons and not for 87.5mm of 88mm bore?
Old Jan 1, 2008 | 05:04 PM
boosstboy's Avatar
Default Re: Je pistons stamped 87m under the crown is this the bore it is inteded for? (jetlude)
no, it's some kind of cast #. i actually ordered the wrong size pistons, mine said 84m so i ordered 84mm pistons turned out to be 85mm bore. i called eagle who i ordered the custom set through and thats when the told me thats just cast # so they sent me the correct pistons.here a pic of a different set also 85mm but has 81m d4. i found out the hard way.
Old Jan 1, 2008 | 06:18 PM
jetlude's Avatar
Default Re: Je pistons stamped 87m under the crown is this the bore it is inteded for? (boosstboy)
Could you tell me exactly where on the piston I should measure
Old Jan 1, 2008 | 06:32 PM
boosstboy's Avatar
ok, i usually take 3 measurements to see my tighest p to wall clearence or biggest part of the piston. take your measurements here then 180 degrees opposite rocking the outside mic slightly to get the most acurrate reading. you can get your piston size from this.
Modified by boosstboy at 8:28 PM 1/1/2008
Old Jan 1, 2008 | 07:43 PM
jetlude's Avatar
Thanks for the info
Dc4LsTeG
Jul 6, 2012 11:16 PM
lsturbo*
Sep 14, 2006 06:07 AM
Benny Z
Dec 20, 2002 03:35 AM
