GSR vs ITR crank. what is the difference if any?
Old Jan 1, 2008 | 11:16 AM
92integraVTECgsr's Avatar
Default GSR vs ITR crank. what is the difference if any?
Is there any difference between the ITR and GSR crank? if so, what is it?
Old Jan 1, 2008 | 03:48 PM
racebum's Avatar
Default Re: GSR vs ITR crank. what is the difference if any? (92integraVTECgsr)
Got me, but you do realize that the crank is the most unlikely piece of a bottom end to go south.
Old Jan 17, 2008 | 08:53 AM
fc3srx729's Avatar
they are the same...
Old Jan 17, 2008 | 09:12 AM
ipodhustle's Avatar
Default Re: (fc3srx729)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fc3srx729 &raquo;</TD></TR><TR><TD CLASS="quote">they are the same...</TD></TR></TABLE>
you don't know what you're talking about.
https://honda-tech.com/zerothread?id=423970
Old Jan 17, 2008 | 09:17 AM
PrinceAli132's Avatar
Default Re: (ipodhustle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by team-integra &raquo;</TD></TR><TR><TD CLASS="quote">The crankshaft is also made with highly rigid steel, increasing it's fatigue limit 25% over the GS-R's crankshaft. Two additional balancing weights were added to create a fully counter-weighted (8 weight) crankshaft improving high-speed balance by 20%</TD></TR></TABLE>
http://www.team-integra.net/se...ID=35
They do have the same stroke though.
Ali
thewrai6th's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ipodhustle &raquo;</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=423970</TD></TR></TABLE>
This is true.
Old Feb 3, 2008 | 12:28 PM
tnez's Avatar
Default Re: (thewrai6th)
they arent the same, but they are interchangeable... the ITR allows for better lubrication/oil distribution. the GSR is lighter but because of the added mass from the counterweights on the ITR, it performs better at higher RPM.
similar but NOT the same...
MidwestAutoWorks
15
Oct 5, 2007 06:24 PM
Baron55
Jan 27, 2007 12:46 PM
BryanPendleton
14
Dec 6, 2005 06:10 PM
Takumi Fujiwara
Feb 24, 2005 09:01 PM
lke2drvgsr
Feb 9, 2004 06:58 PM
