How to replace front lower ball joint for a eg ciivc?
Old Jan 1, 2008 | 08:17 AM
Powered by VTEC's Avatar
Default How to replace front lower ball joint for a eg ciivc?
How to replace front lower ball joint for a eg ciivc? appreciate
Old Jan 1, 2008 | 08:46 AM
zippo1130's Avatar
i would say that you would probably have to take the control arm off, I could be wrong though. But actually holding the ball joint in place is a snap ring, you would have to take the snap ring off and it should come out.
Old Jan 1, 2008 | 10:12 AM
blu eg22's Avatar
Default Re: How to replace front lower ball joint for a eg ciivc? (Powered by VTEC)
You need to take the front knuckle off and put it on a press to remove and install the new ball joint.
Old Jan 1, 2008 | 10:41 AM
h22ek9forme's Avatar
Default Re: How to replace front lower ball joint for a eg ciivc? (blu eg22)
just pull the lca ( takes like 30 min.) and take it to a shop.
we have a place here called "clutch and brake"
I did that in one of my old crxs cost me 14$ to get the old one out and press the new one in.
Old Jan 1, 2008 | 10:51 AM
jameskersten1's Avatar
Default Re: How to replace front lower ball joint for a eg ciivc? (h22ek9forme)
can you actually buy just the ball joint for your civic? i know when I replaced my right upper ball joint last year in my Civic , I could only find the full Upper Control Arm with ball joint from Honda and everyother parts store here in Canada. I didn't mind though since it made the job really easy
MalcolmV8
Apr 5, 2011 09:01 AM
themtn
Honda Civic (2001 - 2005)
Mar 26, 2010 03:01 PM
halocore
Mar 7, 2009 04:34 PM
GruvyTune
Aug 10, 2004 11:30 PM
SleeprCivic
Aug 20, 2003 08:27 PM
