Strut towers
What do I need to do to my strut towers if I want to swap a new accord V6 engine into my 1992 EG hatch, will they need to be strengthened?
my friend tells me the bay isn't wide enough, but i've heard of V8 swaps in the EG, so I know the v6 would fit?
I think you need to research before you worry about strut bars, cause if you our worried about strut bars then it must already be in the car and running.....
you need to research which you will see up at the top of the page and also you should be worrying about mounts,linkage, shifter, wiring, slimfans, headers, intake, ecu, hubs and axles.....
cause I have not seen one of the these v6 swaps done cause I can swap a h22 and make more power for the less trouble...and there isn't prolly enough info on this to get it done so I hope you have lots of money or fab up stuff and good at welding...
